Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.html
Mon Jan 26, 2009 6:46 pm
OK to clear things up if anyone is confused: When I have the car in PARK and the IGNITION ON, Well one day i accidentally pressed the gas pedal and I heard a buzzing noise coming from some where, So I pressed it again and it was a constant buzzing noise till you have the pedal all the way to the floor.
So is this buzzing noise from the engine bay normal with Ignition on and the car in park when you open the throttle a little bit?
Its not comiing from the TCS actuator, Injectors, Throttle position sensor, ABS relays or anywhere else I tried to listen to with the mechanics stethoscope.
