JeffTepper »
https://forums.nicoclub.com/jefftepper-u73921.html
Fri Oct 03, 2014 6:29 pm
Background: I have a '94 Q45 with 138,000 miles. I have owned it for 10 years having bought it from my neighbor who was the original owner (83,000 miles at time of my purchase). I have all service records on the car. Water pump and thermostat replaced by original owner. I replaced plastic fan blade and fan clutch several years ago. Fan clutch still operates properly. Electric pusher fan operates when A/C is on and when temp rises above midpoint on gauge. Recently done the Plenum job including Nissan brand knock sensors. I filled the cooling system with distilled water only, to check for leaks. Car starts right up, runs smoothly and temp rises to and remains at mid point on the temp gauge while idling. It would seem that all is well.
Now the problem: After about 5-10 miles of any type of driving the temp climbs to the point that the needle is about to max out. I immediately pulled over and popped the hood. I noticed that the plastic side tank on the radiator was pissing steam apparently due to a crack below the upper hose nipple. I replaced the radiator with a new one and refilled with distilled water only. I pulled the car up onto ramps and burped the system three times by removing the cap on the radiator itself and monitoring the exodus of bubbles with several blips of the throttle to accelerate flow through the radiator. After three burping cycles I took the car to the local smog guy for its bi-annual smog check and the car passed with no difficulties. However, during the smog test the coolant temp rose considerably with coolant seeping out of the radiator cap above the thermostat flange. After cooling off I drove home (about 3 miles). By the time I got home the temp needle was within 1/4" of leaving the operating range. Stopped the car, allowed it to cool off and checked coolant level. Coolant level in the radiator was still at the notch about 1" below the filler neck. No evidence of coolant loss or steam. More burping cycles, a new radiator cap and another test drive around the neighborhood. Temp still climbing after a few miles.
First question: is the proper radiator fill level the notch about 1" below the filler neck on the radiator? If not, what is it?
Second question, is the use of 100% distilled water during this test run part of the problem?
Third question: Am I doing the burping correctly? If not, what should I be doing differently?
Anything else I am missing here?
Thanks in advance for any suggestions that lead to a "normal" temp during operation.
