zozoka1212 wrote:Why Brembo? Just curious there are planty other companies making as good as Brembo.
Try AP racing or Endless they both have good brakes. ot sure if they have any for M. Can't hurt to ask.
zozo
*****Edit***** just checked it they do make a 6 piston brake set for M.
http://www.stillen.com/browse.asp
Slotted or drilled rotors are supposed to reduce fade after repeated stops, due to allowing quick and easy escape routes for high temperature gasses (heat) generated during braking (friction between pad and rotor).FndMspot wrote:Question, is the OEM brake setup ok for most driving situations or what benefit does an aftermarket slotted rotors/calipers bring to the stopping power or our cars?
The OEM brake system might be ok.........lets stop there. Who wants just ok brakes?The OEM brakes are not that great in terms of dissipating heat. My rotors already needed to be resurfaced at 18,000mi due to warped front rotors. Nissan seems to have a quality issue with the materials they use for their brake rotors.If I'm not mistaken, the first 2-3 yr model Titans had quite a few front brake problems. Low mileage trucks with warped front rotors was one of them.FndMspot wrote:Question, is the OEM brake setup ok for most driving situations or what benefit does an aftermarket slotted rotors/calipers bring to the stopping power or our cars?
lawman12 wrote:Also the new G37 Akebono brakes is another option to keep Infiniti OEM products on the M.
