To echo what Double E said, if they turn the stock rotors (because they are warped), you would only have another 10k miles at best before they warp again and then you will have to get new ones. You might as well replace the stock rotors with high performance ones, that way you may never have to replace your rotors again.Diva5000 wrote:I need brakes for the front tires and smoothing of the rotors. I have a M35 and I would like to know would it be best to take it back to the dealer or to any of those shops that do the work also. Please help me out.
WISHFUL thinking to actually expect ANY rotor to be last the lifetime of car....function of weight of car VS rotor size{weight}....heat disapationdvan wrote:
hrm...i did use the word "may" in that sentence right? Besides, a high quality frozen rotor like the one above will probably last at least 2-3x longer than any stock rotor. So technically, it could last longer than most people would even keep their own cars before selling/trading it in.qship96 wrote:
I have the same exact rotors and after one raining day it will leave rust spots on the rotors. The spots mainly in the middle will not come off.dvan wrote:I just had new rotors and brakes installed on my M45. Performance is excellent, absolutely no vibrations at all when braking.
The rotors I bought were Roto-Tech Cryo by frozenrotors.com http://www.frozenrotors.com/pr...cryo/
Brake Pads were EBC Red Stuff (ceramic).
http://www.autoanything.com/br....aspx
Here is a picture I took with them installed
I had a local auto shop install mine.
Post pics please. Im planning on getting frozen roters...tigerclaws1318 wrote:
Really? Well Ive had these on for a little over a week now and have yet to see any rust develope on the rotors. Its rained and snowed a few times since I had them installed too.tigerclaws1318 wrote:
It could be a possible set of defective rotors just like I might have a defective battery that died in 2 days lol. It is raining over here at the moment and I will take a picture of the rotors the next day. You won't believe how rusted the rotor gets.dvan wrote:Tigerclaws,
So you got the exact same rotors as me? You may have got a bad set of rotors (if thats possible..). I have had my car sit 4 or 5 times over night in the rain plus snow and I dont have a hint of rust on mine, yet anyway.
Hey there, I am looking at changing my rotors as well, on my 2007 M35X, Could you send me the procedure and links as well. thanksloystock wrote:Mopson, I sent you the procedure, including the link to the M35/45 FSM
The ceramic type pads are too hard and cause excessive heat build up. They do last longer than metallic or semi-metallic pads, but the ceramic material will wear down and possibly warp the rotors a lot sooner than metallic type pads.msvara wrote:Just picked up my DBA 4000 6x6 slotted rotors and HAWK ceramics. Front L/R, Rear L/R and pads F/R for $830. Thoughts on pricing?
M
