koza75 wrote:Can someone please recommend the best brakes and rotors for 2008 EX35? To me "the best" would be the ones that can last the longest with performance, noise reduction, anti-dust capability..etc being secondary (but all obviously important enough as well) Thanks a lot in advance!
I thought that in most cases (at least for the big 3 Japanese automakers), the OEM brakes were the option that fit your description as the "best".
For aftermarket pads, I've always preferred the Akebono ProACT pads. I've found that they perform just like OEM, if not better. I like them because they do well in all aspects (stopping, longevity, noise, dust, etc), and also because they cost less than the OEM pads.
As for aftermarket rotors I don't think I could narrow it down to any one single brand or product to endorse, as I've used several different brands on my other cars. The last set I bought were the plain Centric rotors with the black painted hat. I've also used the Raybestos Advance Technology rotors and Napa brand premium (at the time they were the same as Raybestos professional grade) rotors. I haven't had any issues with any of these. Again, they all cost less than OEM.
I'd say that for rotors, you should be fine as long as you avoid buying the 'budget' line of some brand nobody has ever heard of and probably can't go wrong with the premium line of a recognized aftermarket brake manufacturer. You may know this already, but stay away from the slotted/drilled rotors and stick with the standard rotor blanks if you're looking for longevity.
