Issac »
https://forums.nicoclub.com/issac-u89863.html
Mon Mar 31, 2008 12:25 pm
maybe tires like Prozac says, and get them balanced because if you have problems, you tire warantee should cover a rebalance free. Check first.
And/or
Wheel bearings... I had mine seat after I put them in. This means they got loose, and yet were correct on install I thought.
So jack up one wheel, grab top and bottom of tire, push/pull. Any play?Check other side. crank on them and watch your toes. Should not go clunk clunk, or dunk dunk. Mine seated 2 x which really messed me up.
And/or, maybe they didn't turn rotors, doing it on the cheap. The turning is not an automatically done thing by some. So find out from them.
If the pedal pulsates at all this is another sign.
I am putting my money on wheel bearings and tire balance.
Crank your tire pressure up to 40psi and see what happens too.
And the front driveshaft Was causing my vibration at 60mph exactly. So who knows. Do the free ones first and it can't hurt.
