I've got a 1990 240sx hatch with a RB20DET swap that has a weird problem...I just noticed that my brake lights are continuously lit up (yes, the 2 in each tail AND the high-mount center).
I've checked the FSM (
http://www.nicoclub.com/FSM/240sx/1989/1989.pdf) and on page EL-46 I see that "STOP LAMP SWITCH" M23 is the only thing between the tail lamp fuse and the tail lamps. I've pulled the fuse and the lights go out, so I am 99% sure that there is nothing wrong with the wiring because the lights are dependant on the fuse (so there is no short providing continuous power).
Anyways, I want to replace the STOP LAMP SWITCH M23 but I've looked at my brake pedal and couldn't seem to spot it. Can anyone post a pic of that switch or atleast tell me how to locate it?? Once I can find it, I will then need to replace it, so does anyone know how to acquire such a random part??
Thanks,
--TJ
