ziptekhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=7f092dab4f01449b81b48730c1d496ceBrake lights not working!Thu May 05, 2011 4:41 pm
Postby
ziptek »
https://forums.nicoclub.com/ziptek-u139427.htmlThu May 05, 2011 4:41 pm
so my brake lights are not working when i hit brakes, just the third brake light works. ive check all the fuses and the bulbs look good, what else could it be? need some help before i get pulled over and get a ticket. thanks in advance
Postby
Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.htmlFri May 06, 2011 3:19 am
Technical section.
Is your brake light indicator on the gauge cluster coming on when you press the pedal? I'd look at the brake light relay in the hatch. It's on the (USDM) driver's side, mounted in the interior panels in the hatch on the back wall. Looks like either a green or white box with wires coming out of one side.
i just bough a 1990 300zx
i im having the same problem as one the guys here
my brake lights dont work only the little bar on the trunk works
also when i turn my lights at night the tail lights turn on but i still no brake lights. the dash says lights everytine i press the brake peda,dont know if thats good or bad. its the first time i own a Z
Postby
Slipstream »
https://forums.nicoclub.com/slipstream-u31419.htmlTue Apr 07, 2015 7:46 am
Replaced & still nothing. Not sure if I'm getting power up to the relay now there was a short & burnt wire from the previous owner installing an aftermarket wing. The old relay was burnt up inside pretty bad. I'm gonna check it at the switch & go from there.
