tytamto wrote:Did a search and could not find anything pertaining to brake fluid replacement, hence the question:
Which fluid is best to be used? DOT3 or 4?
I have a pressure bleeder, but is there anything tricky about the M when it comes to brake bleeding? I have done many other cars, so I know what I am doing.
I will also need to adjust my parking brake, as it is not grabbing well at all. In my service records, it looks as the previous owner put new rear pads and rotors 3k miles ago (28k miles) at the dealer, but they apparently forgot to take care of the e-brake. Is the adjustment as easy as the service manual portrays it to be?
Thanks in advance.
I am one slowly learning about this car as well. You can use use DOT 3 or DOT 4 type brake fluid. Both are compatible with each other. However, Nissan recommends DOT 3 brake fluid. As for the E-brake goes, if the car has a small internal type drum brake that is integrated into the entire rear rotor, it should be fairly straight forward to adjust. The best thing to do would be to buy a new set of e-brake shoes since you will already be getting into it that far. If the rear rotors were original, I would suggest replacing the rear rotors due to the e-brake drum section being possibly worn. Since you have record of them being replaced this will not be necessary. There should be adequate amount of adjustment there to make them grab enough to lock the rear tires if needed.Then again, if the M cars have acuators instead of an internal type drum e-brake, then all my info listed above was pointless......
I too would like to know what procedures are necessary to bleed the system and decompress the caliper pistons. When my factory rotors are no longer serviceable, I will be upgrading the rotors (slotted/ drilled type) and possibly upgrading the calipers. Let me know what you find out.
J
