Okay.....you talked me into not using the existing speakers with other amps. This is my wife's car, and she's not that fussy about having the highest quality audio. I don't want to spend a lot of money on this, or I might as well just have the Bose parts replaced. I've bought a couple of ESA 2-Channel Amplifier (EA250) amps, one for the front and one for the rear. http://www.circuitcity.com/rps...ew.do Can you recommend some reasonably priced speakers to go along with these amps and give me any tips for installation?PoorManQ45 wrote:Like Rex said, the Bose speakers are either 1 or 2 Ohms.
I don't really see the point of getting an aftermarket amp and keeping the OEM Bose speakers. If you get an aftermarket amp, get aftermarket speakers to go with it.
I think that a 4 channel amp would be good.
Ask and we'll help you find some replacement equipment
Actually, I paid $29 each for them on a Circuit City closeout sale.PoorManQ45 wrote:Very nice buy! 55W RMS by 2 channels for $50 !
*edit* What are the speakers sizes for you vehicle(M30?)? [/QUOTE]PoorManQ45 wrote:What type of speakers are you looking for? Components or Coaxials? What is your price range/Limit?
Hmmm. That is exactly the price range that my 6x9s that I put into the Q45 are in. Go to Car section in your local Walmart. Look for a pair of 6x9 Roadmaster speakers. The box is mostly red, and the cones of the speaker are red too. They should cost about $20 for the pair.91M30 wrote:The rears are 6 by 9, and I believe the fronts are 4 round. Not fussy about speakers, would like to stay in the $15-$20 each range.
Yeah, I was worried about that too, but the manual for the amplifier says "Easily Drives 2-ohm Loads", and also has the following section about low impedance and other protection circuits:Simmsled wrote:Bose speakers are severely low impedance. Those amps do not have internal low impedance protection to know when too low is too low. You have been warned.
I think that you meant to say wire the speakers in seriesRex wrote:Another idea is to run 2 channel stereo off 1 amp with both right and both left speakers wired in parallel to (numercially) increase the ohm load and thus decrease the load on the amp.
Hmmm....I didn't mean to imply that the volume was excessively loud......just that without adjusting anything (the gain was factory set at lowest setting), the volume control on the radio seemed about normal.Rex wrote:The reason the volume seems so loiud, even at the lowest gain settings it the amp is being "over driven" by the low ohm loads of the speakers.
Thanks. I really appreciate the responses, and understand that life of the amp will probably be reduced. But if it does die, I'm only out $29 plus a few hours installation time. In the meantime it sounds as good as it did before the original Bose amplifiers went south. I've run it at pretty high volume for an hour, and the case of the unit is only slightly warm to the touch. Here's some pix of the installation: http://www.villagephotos.com/m...58761Simmsled wrote:Bose's nominal speaker impedance is .49 ohms. I just put 4 of them on the meter. Your amplifier says that it has low impedance protection, but it does not. Those amps can be advertised with all of those protection devices to make you feel warm and fuzzy.
The problem is that the power supplies can't top up the power as fast as the speakers are draining it. THE POWER SUPPLY FOR THE ESA AMPLIFIER IS NOT STRONG ENOUGH TO KEEP UP WITH THE CURRENT REQUIREMENT OF EXTREMELY LOW IMPEDANCE SPEAKERS. That is why it all works. But you will run the amplifier's max current at that specific voltage thru it every time you turn it on and play something. This will shorten the life of the amp greatly and it will die.
But like I said before... you have been warned. But I wish you the best of luck!
Interesting. My wife's car is a 91, and if the rear speakers in this Bose system are actually above 2 ohms, that may be why after several days the system still sounds good.audtatious wrote:Not all Bose systems are <1ohm. My '02 has 4ohm tweeters and something like 2.95 ohm mids.
Check the speakers with a multimeter and design the system accordingly.
I just found the following on another website:Rex wrote:There should be a setting for Ohms, the Omega icon??
Just tap the multimeter leads to the speaker terminals and it should disply the resistyance.
