I am trying to install the PAC AAI-NIS2 Aux Audio Adapter in my 2004 Infiniti G35 Coupe with factory Bose, no SAT. In doing so I destroyed the factory speaker plug (6 pin) that goes into the back of the factory head unit. I purchased a Metra 71-7550 to replace the factory plug.
There are 6 wires from the factory harness: orange, gray, yellow, pink, blue & green with yellow stripe. I am trying to determine which of these wires goes to which speaker in order to install the Metra harness correctly. It is only the rear speakers that are affected; with the Amp wire connected the front and mid speakers work.
I found the "wiring diagram" below on modifiedlife.com (
http://www.modifiedlife.com/car-stereo- ... g35-coupe/ )
I have indicated (in all CAPS) on the diagram which wires are coming from the factory harness.
2004 Infiniti G35 Coupe Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: YellowRadio Switched Ignition 12V+ Wire: Light Green
Radio Ground Wire: Chassis - UNSURE WHICH IS GROUND WIRE COMING FROM FACTORY HARNESS
Radio Illumination Dimmer Wire: Red/BlueRadio Antenna Trigger Wire: Green/White or Red/White
Radio Amplifier Turn On Wire: Green/Yellow to Light Blue - CONNECTED TO AMP WIRE
Front Speaker Size: N/AFront Speaker Location: N/ALeft Front Speaker Wire (+): White or BlueLeft Front Speaker Wire (-): Black or Black/WhiteRight Front Speaker Wire (+): Green or BrownRight Front Speaker Wire (-): Red or Black/RedRear Speaker Size: N/ARear Speaker Location: N/A
Left Rear Speaker Wire (+): Brown or Light Green - NEITHER PRESENT IN FACTORY HARNESS
Left Rear Speaker Wire (-): Yellow or Black/Yellow - YELLOW PRESENT IN FACTORY HARNESS
Right Rear Speaker Wire (+): Blue or Orange - BOTH PRESENT IN FACTORY HARNESS
Right Rear Speaker Wire (-): Pink or Black/Pink - PINK PRESENT IN FACTORY HARNESS
Could anyone tell me how these connections should be made?
Thanks in advance for your help.
