Your 2 ohm amp wouldn't have a problem powering them - but IIRC, the Bose amps had some built-in "equalization" (i.e., the amp's frequency response was shaped to match the response of those particular speakers). You could probably come pretty close to matching that frequency response with an equalizer of some sort - Probably isn't all that critical anyway.Wiggler wrote:I know it's been covered more than once, but please humor me...
Ok, so if the factory speakers are 2 OHM, Could I still use an aftermarket amp (like most of them) that are 2 ohm stable?
I doubt that Bose even published a maximum wattage spec for those speakers. By today's standards, it's gotta be pretty lame.What is the max wattage rating of the stock speakers anyway???
Ok, yes, you are right about the wires FROM the HU... but I could tap into the output harness wires from the Bose amp TO the speakers to avoid running extra wire...right? Oh, and the front door speakers in the Y33s look like an asymmetrical 5.25" size.... anyone correct me if I'm wrong. Does that mean they are 1 ohm or 2 ohm? Car audio outfitter websites say it takes a 6.75 in the front.... probably only with some sort of adapter or spacer...maybe minor fabrication is needed...SanCarlosQ45 wrote: Don't use the existing wiring from the head unit because those are meant for line level signal, so the wire is not high enough gauge.
Given all the noise reduction padding that probably went into the body panels, I don't think insane power for 2-way components is necessary... I'm probably going to use one of my class A/B 30w RMS 4 channel amps with better sound quality than a high powered Class-D pile of junk. I used 16 ga. wire straight to the speakers in my Fozzie, because older Subarus have more nooks and crannies to run speaker wire. and because of better proximity to the amp. (mounting under seat). I don't think any under-seat mounting options are in the cards for our cars...SanCarlosQ45 wrote:Sorry I didnt do any looking to see what size they are. They are ~6.5" but are still 1ohm. I'm not sure why they liked such a low impedance in the nineties. Its wierd that they use a single amplifier for the front speakers in the trunk and then have individual amps for the rear.
You could use the wire running the front speakers if you wanted, but remember this was meant for the Bose speakers which are 30-50w RMS so it may not work for other after market components that can run into 150+ watt range depending on what amplifier you choose. I ran 16ga from the trunk to the front doors for this reason, but if it is 18ga it might be okay.
