Yea I know most of the stuff will cross to a Z32TT with exception of maybe an arm or two that is instead shared with S13's. Did you use the inner or outer boot from a 90's Maxima? I have a 91 here that I can probably crawl under and measure, but you can also save me the trouble
. I believe it's my inner front right boot that is totally gone. The problem I see is that CV axles don't last forever due to the constant amount of sharp angle turns that we put on them while rotating. Knowing and being able to get an entire axle replacement is what I am getting at. The front right axle resembles the usual axle off a front wheel drive car(maxima?) where you have to pop it out with a prying tool (unsure about spline count on both ends and length). The front left axle looks a lot like the stock rear S13/14/15 axle with a 6 bolt flange in a '2bolt x 3wing' arrangement (again, unsure about spline count difference and length).
