Cytrakz wrote:Alright thanks a lot. I'm working on getting the compression test done asap, then ill let you guys know what happens. How much would I be looking at to have it fixed if it were just the HG and how much would it be if it were pistons, rings, etc?
HG I would estimate for parts to be about $900. Just a rough guess - gasket kit, timing belt kit, belts/hoses, machine shop costs. Labor would be insane if you're paying someone to do it. I think book time is 22+ hours.
Replacing rings you are looking at a complete teardown. Might need a bore also. Pistons, rings, wrist pins, more machine shop costs, would bring you close to $2000. Labor again is something that hurts to think about lol.
Be sure to do a wet compression test on any low cylinders, that will help you verify if it's a ring problem. Also it's a good idea to do a leakdown test...Do all of the diag you can before coming to conclusions -- we are talking a lot of money here
