MrInfinit_E wrote:Let's see if I can be of any help to you. The location of the fuse box for all the interior lights and switches is located on the side wall of the driverside near the bottom right next to the parking brake. Once you open the little compartment there is a diagram that shows you what every fuse is for. Test for the burnt ones and just replace them. Second there is another fuse box, this one hold the fuses for all exterior components such as tail lights, horn, etc. The location of this box is under the hood. First lift your hood and then locate your battery compartment remove that lid and then you will see a little black box this is where the fuses are remove that lid see the diagram on it as well test the fuse remove and replace. Viola......hope I helped.
msvara wrote:What you're saying is the lights that turn on while the main headlights are on for example during night driving are not working?
Here are some questions back to you:
Do the daytime running lights work? For some reason I dont have daytime running lights....I didn't even know the M's have daytime running lightsDo the rear brake lights work without the headlights turned on?Break lights work without the headlights on but obviously only when i press the breaks
For the interior lights did you turn up the interior light control switch all the way? (Hey, you'd be surprised how many ppl don't check)Yup I checked that
Just a guess without further information it could be a bad relay. Or possibly just the contacts. If you find the fuse/relay box in the engine bay on the same side as the battery and re-seat the relays. Guess I'll check this tonight
Ok so I check both fuse boxes(interior and engine bay fuse box) and checked all the fuses with a continuity checker and all the fuses are ok.antzrus wrote:I haven't played w/my fuses since I've owned my M. But I know that fuses sometimes are hard to assess if they are blown or not. I would suggest you use a continuity checker (multimeter) to make sure. It seems peculiar that your fuse would not be in the usual places.
Did you figure out the problem?I have the exact same problem as you, no interior lighting, no taillight when headlights are on. I don't have the fuse box cover so I don't know which fuse is assigned to what.pmtran16 wrote:I blew the fuse the that is connected to the interior lights that lights up the dash/temperature controls/center dials/misc other dash lights. I guess this is the same fuse that is connected to my taillights and license plate light cause when i turn on my headlights, the headlights turn on but neither my tailights or license plate light.
Does anyone know what fuse controls all these lights and where I can locate it? I want to buy the fuse and fix it myself instead of going to a infiniti dealership to have it done.
Please help
