Q451990 wrote:The readings are close enough that they're probably within the margin of error between the two meters.
The circuit breaker should not be directional.
Heath
The multimeter's are identical but the temps the reading were taken at isn't.
rioredstang wrote:OK Paul I will look up power distribution on that circuit tomorrow. We can break down each component and see who's causing the short. I'm not concerned with amp draw at this time.
The circuit breaker literally went up in smoke...I had the power window, seat and ADP circuit breaker plugged in already and the systems worked when I plugged the 25 AMP circuit breaker. But then I decided to take a risk and plug in the power window and I saw smoke coming from somewhere near the SMJ*. I did'nt see the exact place the smoke was coming from because I was worried about the smoke.
So lesson learned: Circuit breakers suck No disrespect but be careful who's advice you follow on a forum.
Thankfully I found the reason there is water in my trunk I think. I fixed the dome light where one bulb stop lighting up.
I hope when I get a fuse that the windows, door locks...All work because the multimeter says they are OK but I want to be sure. The multimeter registers 12.xx volts and 2.xx ohms.
