Here's my story, about a month ago at the drags I did a run and noticed smoke pouring out of my hood. Opening the hood revealed what looked like oil that had gone everywhere in the engine bay, the exhaust side of the block was mostly covered in front of the turbo, the piping, where the coilpacks sit, the underside of the hood, and some even made it to the passenger side wheel well...After some inspection of the damage, we determined that my power steering hose had sprung a massive leak (a quarter inch split in the hose) and the power steering resivoir was mostly dry, so I figured in the process of going lock to lock around the water box (too poor for slicks) I blew it. So I got a new one from Rawbrokerage (thanks!) and installed it, much to my happiness, everything was fine, no more leaks, no more turning like a granny...
Flash forward to this morning...hopped in my car and messed around with my nistune a little bit, it was running rich when it was cold(10:1) so I dialed that back a little bit and called it good. The car was warmed up (150F-165F) and I hammered it on the onramp to the freeway. I noticed after I was off the throttle that there was quite a bit of smoke trailing me, so I got off at the next exit to check on everything...once again...oil everywhere...power steering hose is brand new, resivoir level is fine, oil level is low, and that's what it looks like...so here's some pictures of the second time...the oil is comming from the top of the motor I'm pretty sure, the piping is coated on the top, but pretty much dry on the bottom...maybe pcv and my breather...I've just never heard of this kind of spray from a breather.
My motor is an RB25 with an HX35 boosting about 14psi, so not super high boost or anything...thanks if you can figure it out.
