So I was having what I thought was the fan amp go out on me on my 98 q45t. I went to the junkyard and got one from a maxima replaced it and still the same issue (blower motor not running). so I started looking for the fuse and the relay. When I bought the car it was missing the kick panel for the fuse cover and I don't know what fuse is what. Needless to say I've been looking everywhere for a diagram of fuse location or the location for the blower motor relay with no LUCK! Could someone point me in the right direction or know the location of the fuse and relay for the blower motor?
EDIT: The fuses for the blower motor are #1 and #15 the relay is located on the backside of the fuse panel closest to the drivers door.
I ran a fused wire to the blower motor to make sure it was working, and it was. Next I took the relay from the blower motor and swapped it with the fan relay under the hood and Bam! blower motor is working fine again. ill need to get another relay for the fan in the morning but at least I got it figured out.
