I've bled it and ll should be good however it is not.
My Question: How powerful or how should the fluid come out when you bleed it at the TC (Clutch Pack Actuator) case?
Debate: I remember when I bled my other transmission's transfe case (Cluch Pack Actuator) and the fluid shot out of the bleed valve. I bleed now and it seems the fluid is not coming ot at the pressure I remember, comes out in steady stream but not shooting out.
If this is the problem what can lead to this?
