Anyway im building an SR20DET and about to put in some brand new pistons!
![Big Grin :biggrin:](./images/smilies/biggrin.gif)
So i measure the cylinders and they are all sized well, nice and round with very little taper everything is going well until i measured wall thickness (basically just looking for coreshift using an ultrasound). The machinist thats advising me told me that .0950" was his limit for wall thickness and one portion on my 4th cylinder measures .0946" which is no big deal but i noticed alot sites want to sell 86.5mm pistons. (Some companies actually dont even make 86mm pistons i.e. Tomei)
1. I dont know where he got his .0950" number from
2. He worked on mainly American cars but knows alot about pretty much all cars.
3. If i did a .5mm overbore it would put that wall thickness at .0750"
(sorry for using standard and metric numbers)
So the final question is:
Does anyone with credentials know if the stock cylinders/block can handle being .0750" thick?
Note: Im talking about the distance from the inside of the cylinder to the nearest cooling jacket.
The cylinders dont have much wear so i would essentially be taking .5mm off the stock sleeve. Im hoping to end up around 400hp. Theres also a possibility im just being way too cautious.
