Nissan dominates the drift scene - Always has, always will.
best engine swap for drifting
Postby nissandrift818 » Sun Dec 19, 2010 5:19 pm
i currently have a 240 s13 with the original ka24de,and i want to do some modifications for drifting.Can anyone suggest what engine should i swap in order to get there,or maybe just keep the ka.
nissandrift818
Car: nissan 240sx
Re: best engine swap for drifting
Postby Eikon » Sun Dec 19, 2010 5:26 pm
You can either turbo your KA or swap in a SR20det
http://www.240sxconvertible.com - The internet's only 240sx 'vert site!
Joshua 1:9 "Have I not commanded you? Be strong and courageous. Do not be terrified; do not be discouraged, for the LORD your God will be with you wherever you go."
Eikon
Car: Subaru BRZ
Postby nissandrift818 » Sun Dec 19, 2010 5:47 pm
yea i was thinking of those two,which one do you think will be better?
nissandrift818
Car: nissan 240sx
Postby Eikon » Sun Dec 19, 2010 6:06 pm
It depends entirely on your budget and mechanical experience. Use the search feature.. there about 10,000 threads on the which engine is better.
Eikon
Car: Subaru BRZ
Postby mixeds14 » Sun Dec 19, 2010 8:51 pm
or u can go rb, 2jz, ls, ca... u dont need a lot of power to drift, u just need to know how to do it... power is useless if u dont know how to drift
slap a turbo on ur ka along with some other goodies n when u get experience, get the power.. just some suggestions..
s14-neo 6 inside...
mixeds14
Car: 240
Postby boarding2008 » Sun Dec 19, 2010 8:59 pm
^x2 you really dont need much to get sideways. i have a stock ka24e with a welded diff and have no problem drifting with it.
92 civic hatch - current project - z6 300+whp
89 s13 fastback - 100% stock...for now
boarding2008
Car: 89 s13 fastback and 92 civic soon to be 300whp boosted single cam
Postby orangeNblue » Mon Dec 20, 2010 8:46 pm
1uzfe is an affordable swap that has a ton of torque or a vh45
orangeNblue
Car: 2008 Nissan 350z
Postby slikklogic » Sat Dec 25, 2010 2:20 pm
im new to a nissan but i got a stock s14 with a exhaust and 1 piece coils.i bought a junkyard j30 rear, shimmed it and redid all the brakes. car drifts lol stock clutch and all 1st and 2nd make alota tq with a ka.spring im goin KA-T with a sr based setup (t28,370cc inj) jus becasue im not looseing ac and ps lyk i did on my last build lol
slikklogic
Car: 99 honda civic 1.8T!
95 240sx base/se
Postby speedeast » Sat Dec 25, 2010 2:40 pm
You want to know why the KA is the best option for you? You already have it. Build the KA and you're good to go.
Need motivation?
VH --> S13 Wiring How-to
Check out my BUILD! PICS!!
Hear me roar!
First - Resolved - Warm
XBOX = Zalcon
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Postby slikklogic » Sat Dec 25, 2010 11:58 pm
:ohno: :dblthumb: :mike ^^^^lol
slikklogic
95 240sx base/se
Postby AZ89two4Tsx » Sat Jan 01, 2011 6:05 pm
orangeNblue wrote:1uzfe is an affordable swap that has a ton of torque or a vh45
LOL
89 Sil40 - SOLD
E34 540i 6 speed - SOLD
89 S13.5 - SOLD
03 Maxima SE
AZ89two4Tsx
Car: 03 Maxima SE
Postby ricers1 » Thu Jan 20, 2011 5:48 pm
get a 89 750i v12 from a bmw, ebat for 650. loads of torque!!!! :yesnod
ricers1
Car: 1990 240sx
Postby Miamiman323 » Wed Apr 13, 2011 8:10 am
SRs and KATs are for people who suck at drifting. The only way to take advantage of your awesome drifting skillz is a full blown Merlin swap. I mean c'mon, if you cant clutch kick it sideways at 50 in 12th, how cool are you?
http://en.wikipedia.org/wiki/Rolls-Royce_Merlin
Miamiman323
Car: 1993 Silvia front 240sx Vert w/ red top SR20
Postby Miamiman323 » Wed Apr 13, 2011 8:12 am
BTW, you may have to massage your firewall slightly ;)
Miamiman323
Postby ashibah83 » Sat Apr 16, 2011 5:31 pm
while the merlin is nice, i wqould opt for the BS13....
thats Briggs & Straton 13hp.......moar light weight to keep the handling balance in check and prevent understeer from too much forward weight...
Quote, originally posted by ppctx »
Talking to a non car enthusiast friend yesterday. He said "I bet you feel like a bad a** driving around in the car", I said no, I play little games like “what’s that noise” and worry about what's going to break next.
ashibah83
Car: 93 SUPA BLACK COUPE
Postby corn322 » Tue Apr 26, 2011 9:54 am
LS3. Lighter than a KA, 400 hp stock, probably gets the same gas milage.
corn322
Car: 1993 240sx
Postby Dom Sacco » Mon May 30, 2011 9:07 am
I'd stick with the KA considering you already have it. For starters you should more so focus on a nice suspension set up. That will make or break your drifting. If you plan to only drift the car then do as many deletions as you can to clean up the engine bay and relocate whatever you can to the rear of the car to get as close to a 50/50 front to rear weight ratio. (not everyone I know goes for that weight set up so I guess it's all preference and what works best for you) Do some simple mods like intake and cat back in between all that THEN start looking into a turbo set up. Just my 2¢
Dom Sacco
Car: '91 Z32 NA Slicktop 2+0
Postby spec-u-later » Mon Aug 01, 2011 4:30 pm
Take care of your suspension first. Get a good diff, I love my KAAZ 2-way but it depends on your preference. Run the stock KA for a season or two till you're really comfortable drifting and the lack of power is holding you back. I did very well on just a stock KA with IHE. After that you can start looking for swaps or turbo options.
(With a straight face)
"I live my life one 1/4 pounder at a time...................."
spec-u-later
Car: 06 G35 Coupe 6mt
96 S14 (4 SALE)
06 GSXR 750
92 Corolla
Postby nismo_200sx » Sat Aug 06, 2011 9:09 pm
ca18det. cheap, reliable, bulletproof, good top end, fairly easy to upgrade, stock fuel rail holds 450hp, ecu is easily tuned, cheap heavy upgrade parts like a stroker kit for 2 grand off of tomei if you can find one or norris designs. ca20det cheaper and s*** on upgraded sr's all day v8's are nose heavy reguardless of what people say they weigh, plus boost is better than being n/a and its oem turbo engines so no need to worry if you hit 12lbs on a t25 parts are dirt cheap. so unless you wanna spend 5 grand on an lsx engine swap and custom fabricating s*** then dont do it
nismo_200sx
Car: Nissan 200sx in progress of ca18det swap
Postby impact240sx » Tue Aug 16, 2011 11:11 am
WOW :spitout: This thread really has it ALL!!
-You got the broke folk with ka's sayin ka's are sick cuz they have one, they won't tell you they drift in the rain, and don't go to tracks due to the na ka embarrassment.
- Next up is the guy with a v8 that will claim things that arent even true to make his motor look superior.
-Then, typical ca lover that says a bored and stroked ca (20) is cheaper than an sr20.....ok maybe thats not typical just lame.
-Oh and the typical v8 haters, that literally dont have a reason to hate.
But in all seriousness dont ask people about motor swaps. Just do dome research, motors are all personall preference.
I slide my sr just because thats what i switched to once my ka blew up, and since i like them i've got 3 of them, and i'll slide with my vq here and there. I'm really not biased anymore what motor i use, just find one that suits you and enjoy it!!
93' S13 Blacktop Gt2871R Stance GR+Pro's 330WHP @17PSI
impact240sx
Car: 1993 240sx Sr20det Gt2871R 2003 350z 1991 240sx Sr20det 2004 Land Rover DISCO
Postby spec-u-later » Tue Aug 16, 2011 5:27 pm
Read a little closer impact. I'm saying get some skill before you go crazy with a swap. I started the KA, I swapped to an SR...Big effin Deal. BTW I have competed with the KA and did just fine in my first two events placing 5th in both out of 32 with entry fields over 200 a few a few years ago.
spec-u-later
96 S14 (4 SALE)
06 GSXR 750
92 Corolla
Postby impact240sx » Tue Aug 16, 2011 6:50 pm
Well first off he didnt say that money was an otion, and obviously if he's considering motor swaps he isn't reallly enjoying the lack of power. I wish I would have swapped to sr to begin with. I wasted alot of money with ka's before going sr.
And it still doesn't change my suggestion, Find out what motor you prefer then make your preference a reality.
And spec-u-later you might be the exception to the rule but i deal with "KIDS" all the time running their mouth about how sick there ka is/was and how sr is a waste of time, but the reality is a stock ka on average doesn't really cut it.
impact240sx
Return to Nissan Drift Forum
