m0nkeyprince »
https://forums.nicoclub.com/m0nkeyprince-u164086.html
Mon Jul 09, 2012 3:08 pm
well for rotors, you could try DBA (disc brakes australia) if you have the money.
I went with EBC slotted rotors because DBA didnt make a disc for my 98 qx4. For disc brakes, the most you want is slotted, never go with drilled as it lowers structural integrity can crack
For pads (which make a big difference in braking performance), I went with Hawk LTS which is a ferro carbon compound similar to their HPS pads but better. Same amount of dust as regular pads though with alot of stopping power, no noise though.
If you want to go a step up, EBC yellow stuff is great for more stopping power
if youre more concerned with noise and dust, you can go with hawk ceramic pads
whatever you choose, after you install your new setup, you have to "burn" in your pads to your disc by making high speed severe stops. NEVER clamp on you brakes and make a full complete stop while youre burning the brakes in as you can make a "hot spot" (safety a priority first though). i forgot the specific speeds you go to but i think its 50 mph tp 5 mph 4 times then 30 to 5 3 times, something like that, that you can look up.
Also, if you havnt, bleed your brake fluid with new fluid, that also improves braking performance (depending on how bad your old fluid was), I use ATE super blue
