captluv »
https://forums.nicoclub.com/captluv-u46148.html
Tue Sep 12, 2006 6:28 pm
I'm still waiting to wake up from this one, knowing all is really well...Started changing the belts on my 96 I30 today and I got the accessory belt off (alternator, ac), but the power steering was a 5-hour disaster. Here's what happened.
I found the bolts on the front of the pump and loosened them, but too much as the two-bolt assembly fell out and I couldn't put it back in, no matter what I tried. The compartment is too crowded and the car frame blocks my view of right where I need to look. I eventually lost the smaller bolt and that rectangular brass piece somewhere in the engine bay. Just disappeared, vanished without a trace like William Hung's popularity. I had to order a new block from Nissan ($14, thought it would be worse).
But here's the biggest problem, I think the power steering pump has another bolt somewhere behind it that also needs to be loosened (I saw a drawing, probably from a Chilton book, on Maxima.org). The belt is still on; can't get it off.
So, I have two questions:
1. Is there a second bolt behind the pump somewhere that I need to loosen as well?
2. Does anyone have experience reinstalling the long bolt and block assembly that adjusts the power steering pump? I imagine if you've ever had to remove the pump and install a new one, you've done this.
I hope this all makes sense and someone out there can tell me how to get the belt off. Thanks in advance.
