Just wanted to update this again for future troubleshooters. Turns out the braided PVC Home Depot special BPV recirc line I was using had been charred to a burnt black crisp with a few holes in it by the exhaust manifold it was sitting above. It was difficult to find this initially because it was just on the underside of the pipe. Replaced that with a 4 ply silicone piece so that should be safe now. Problem instantly went away and it pulls hard all the way to redline.
Amidst all this trouble shooting/messing around I replaced the injector insulators/donut o-rings on all 6 because one had a decent rip in it, and a couple others were questionable. At the same time I pulled the injectors out and reinstalled them as CarlH recommended and replaced the PCV valve and seal.
The problem now is that every time I boost relatively hard, I smell pure gasoline. I've stopped quickly after boosting to look for leaks but all I can see is that the injector bodies are damp. I ordered a new set of o-rings from deatschwerks and re-installed them again carefully drying the bores, lubing them with a small amount of fresh oil, lightly oiling the o-rings, and pressing them in by hand with a correctly sized socket on a ratchet. But I'm still getting the same problem...smell goes away and doesn't happen under regular driving/low boost. --I'm headed to Dynojet within the week to put the car on the dyno and get a baseline run as well as monitor the injector area under load.
One last thing - My semi-erratic idle seems to be from a mildly leaky intake manifold gasket. Discovered via spraying starter fluid near intake manifold gasket/head boundary at idle. Strange since I re-gasketed the whole engine with new Nissan gaskets before I ever ran it...
