Bee*R Power Builder HELP!!
Postby Ikera » Mon Apr 23, 2012 3:19 pm
I got my hands on a fried Bee*R limiter
looks like an exploded resistor, I think I might be able to solder a new one in place if only I knew what type of resistor it was.
So I need help from someone who has Bee*R limiter in accessible place, if someone could pop the cover off and take a picture of the resistor that I'm missing (R18) or at least list the colors of the rings on the resistor.
No tools required for this, the Bee*R rev limiters covers just snapped into place and can be easily popped off.
The spot for the exploded resistor is labeled R18
Also does anybody know how does the Bee*R limiter work?
How does it stop the ignition? because cutting ignition wire is not part of the installation procedure.
Ikera
Car: Nissan 240sx KA24E
Re: Bee*R Power Builder HELP!!
Postby Ikera » Tue May 08, 2012 5:05 pm
bump help!!
Ikera
Postby spitfire » Mon Jul 02, 2012 5:50 am
Do you still need help?
I tried to open mine this morning by undoing the 4 screws, but they just turn.. I saw the tabs for popping off but didn't want to force it in case the screws had to come out first.
spitfire
Postby spitfire » Mon Jul 02, 2012 9:00 am
Mine goes Brown, Black, Gold, then thin gold on the end.
My unit doesnt work (light comes on at set revs but never limits.. can't see anything wrong inside? :(
spitfire
Return to 240SX Technical Forum
