BBK wheel spacer information!!
blueM35x
Car: 2006 M35x, twilight blue
hey guys...im doing the G37 bbk upgrade on my 06 M35x..I want to know what size wheel spacers I need...I also have the factory 19inch sport rims on...Im not sure if its 15mm or 20mm or 25mm
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
15mm is the minimum you'll need to get them to fit the OEM 19's
blueM35x
thanks!!! also do i get the spacer with the studs or just the spacer alone?
bbs350z
Car: 350z built tt
350z st track whore
m35x daily
evo 8- 30r sold
you would need either longer studs, or a spacer with new studs in it. i know the v2 ichibas have studs pre pressed in while your factory studs go through the holes
blueM35x
thanks for the info!!!
06M4.5
Car: 2006 M45
I would get spacers that get bolted down (in other words 5 holes with 5 studs), it would be safer. I would take a look at H&R's to see is they have them.
tolete212
blueM35x wrote:hey guys...im doing the G37 bbk upgrade on my 06 M35x..I want to know what size wheel spacers I need...I also have the factory 19inch sport rims on...Im not sure if its 15mm or 20mm or 25mm
i did the upgrade couple of months ago get the 20mm... v2 ichibas.
im uploading pics tomorrow so you could see
blueM35x
did you get the spacers with the studs on them or studs seperate??i need to order them today...some are telling me to get the 15mm and some are telling me get 20mm...i have stock 19in sport rims..
tolete212
i have them with the studs on them, those are the V2 and i have the 19" M45 rims.
JasonR
Car: 06 M45 Sport
Nice to know yor guys are local in NY and NJ area ....where did you guys source the BBK from?
blueM35x
thanks for the help...what did you order for the rear? and what did you do?
blueM35x
i bought mine from the dealer straight up...at circle infiniti in west long branch nj...talk to tony..he'll hook u up
DoN_BLaZe34
2006 FX45 - Traded
how much if you don't mind me asking
blueM35x
460 for the front calipers, 400 for the rear calipers, 200 for the spacers and for the pads and rotors I use my own parts store for them
tolete212
i have 20mm with 19" wheels
blueM35x
Looks real good!! Doesn't look like the wheel sticks out too much!
:bigthumb:
tolete212
yeah it doesnt..i just need to get some coilovers and ill be good.
blueM35x
They make coilovers for the X??
rgb129
Car: 2008 550i sport
RIP 2006 M35x
blueM35x wrote:They make coilovers for the X??
K-Sport...My car was for the development for this kit.
bbs350z
Car: 350z built tt
350z st track whore
m35x daily
evo 8- 30r sold
more pics of of your car please!
m4m
Car: 2009 M35S
blueM35x wrote:did you get the spacers with the studs on them or studs seperate??i need to order them today...some are telling me to get the 15mm and some are telling me get 20mm...i have stock 19in sport rims..
blueM,
How big of a spacer did you get, was wondering if 15mm was indeed enough to keep our stock 19s? If you have completed your BBK set install, can you post up some pics please?
DoN_BLaZe34
2006 FX45 - Traded
blueM,
15mm should be fine to clear the stock 19's..some ppl (as seen above) have gone with 20mm
blueM35x
So here is the update with my install. sorry for the dirty car...as you know the storm was nasty..and my iphone picture quality sucks..but oh well..
ok so im doing my bbk right now as we speak....i actually ran into a couple of problems...
first is..can't use the original brake lines on the M, the M brake lines have a banjo bolt fitting and the bbk has flared out nut..no one has mentioned this but it might also be cause my car is the all-wheel-drive. you don't have to get the brake lines from the dealer you can actually have them made...had to find this out the hard way...
Also i used 20mm ichiban v2 wheel spacers for the oem 19 sport rims...
the tires do stick out about 1inch..i am not sure about the 15mm spacers cause it looks like there's about 1/4 inch clearance from the calipers to the rim...I will stick with the oem 19's for now..but I am thinking about trading anyone with the stock 19 inch G37 sport rims..only cause you do not need spacers with those.
As for the rear install...you have to cut the dust shield as the rotor and caliper won't fit..the dust shield hugs around the rotor so I wized off the looping part
im going to give you guys the complete part numbers i used to do this bbk install.
pictures of just for the fronts cause im waiting for the rear brake lines to arrive..
1.Right front caliper (1) 41011-JL02A
2.Left front caliper (1) 41011-JL02A
3.Right rear caliper (1) 44001-JL02A
4.Left rear caliper (1) 44011-JL02A
5.Pin(for brake pads) (8) 41217-JL00A
6.Clips(for the pins) (8) 41218-JL00A
7.Front brake hardware kit(1) D1080-JL00A
8.Rear brake hardware kit (1) D4080-JL00A
9.Right front brake line tube(1) 46245-JK60B
10.Left front brake line tube (1) 46246-JK60B
11.Right rear brake line tube with bracket(1) 46315-JL00A
12.Left rear brake line tube with bracket(1) 46316-JL00A
JasonR
Car: 06 M45 Sport
Niceee! Where did you find the BBK from?
mexillis
Car: M45s
its in other threads that you need SS brake lines in order for this to work, which are anywhere from $75 on up. I really want this upgrade but have other priorities right now. Good work so far!
blueM35x
jason..i bought the bbk from the dealer..circle infiniti...
mexillis..i didn't see that thread..oh well...instead of the ss..i ordered the original brake lines for the g37s..thanks
DoN_BLaZe34
2006 FX45 - Traded
mexillis wrote:its in other threads that you need SS brake lines in order for this to work, which are anywhere from $75 on up. I really want this upgrade but have other priorities right now. Good work so far!
that's exactly how i feel...
so the 20mm spacers sit flush on tolete's car, but they stick out on your car blue...that's weird.. :wtf2:
blueM35x
maybe cause its in the air?? i dunno man...there's another person on the forum with a white m45 that did the bbk...he painted it white with akebono lettering...and he said he used the 20mm spacer...and it looks fine...maybe the spacer they sent me was 25mm? i gotta check it tomorrow when i go back to the shop...i think 15mm should be ok...but im not sure about that just cause the clearance from the caliper to the rim....blah...if that's the case then i guess i should get the 15mm...but what to do with the 20mm?? i hate this trial and error crap...oh well..i have a lot of work to do and my car is stuck on the lift...shat!!! :gotme
DoN_BLaZe34
2006 FX45 - Traded
You figure the offset on the OEM 19"s is +50...and the G37 19's are +30...so adding a 20mm will make the M 19's offset go from 50 to 30 which is why is the 20mm should work fine..
The real test will be to have the car on the ground..if it sticks out, you can always sell the 20mm spacers if need be
Also, getting someone to trade you their g37's wheels for your 19's will probably be a little hard..good luck though
blueM35x
hmm...i have a feeling they sent me 25mm...gotta see how it is on the ground...tomorrow will be the day...
yes it will be hard...but im trying to see what my options are...i did spend a good amount of money on this car already where i told myself i wouldn't upgrade anymore...but hey..its in my blood..
im thinking of sending back the spacers and getting the 15mm..
