Code: Select all
Wire Gauge Recommended
Maximum Fuse Size
00 awg 400 amps
0 awg 325 amps
1 awg 250 amps
2 awg 200 amps
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
These are the recommended maximum fuse ratings for the corresponding wire size. Using a smaller fuse than what's recommended here will be perfectly safe. I just relocated the battery to the trunk 2 weeks ago and im using the circuit breaker in first link you posted.allenms240 wrote:Are there any fused distribution blocks or circuit breakers that you would recommend?
Stock should be 4GA... not sure on the plugs. There are also tons of custom options available for the wiring setups and battery boxes. For grounding, welding cable is your friendallenms240 wrote:What gauge wire is the stock starter cable, and the two plugs that plug into the positive terminal?
Stock starter cable - 4gallenms240 wrote: What gauge wire is the stock starter cable, and the two plugs that plug into the positive terminal?
