masbirdies »
https://forums.nicoclub.com/masbirdies-u92247.html
Sat Mar 15, 2008 2:25 am
As for a little history on the car, we bought it new in May of 06. As of today, the vehicle has about 58k on it.
Over the last year, I've had a few occasions where I had to jump the wife's Quest. Typically, this would be from cleaning out the car and running the radio for a long time, leaving lights on in the vehicle overnight, etc....
I thought this was a bit odd but... after the jump things were fine.
About 2 months ago, I noticed a lot of corrosion around the positive terminal. I cleaned it off real good and checked the water levels in the battery. They were a little low but not much. Topped the battery off and off she went.
About two days ago, my son was driving the car. He said the lights on the dash went wacky and the vehicle, all the sudden, would not run. The vehicle would jump star and idle but would die when we tried to move. A 20 minute charge via jumper got enough in the battery to get us the rest of the way home.
I pulled the battery and took it to autozone and they said the battery was bad (they charged it and put it on a tester). So, I bought a new battery.
My question is... when I was taking the battery out, I noticed the corrosion had reappeared. Not terribly but...I have an 04 vehicle that is spotless.
Also, I noticed that the positive terminal was not as tight as I would of liked. It was snug but had some minute play to it. It could have been tighter.
My gut is telling me that I still need to replace the alternator. Could it be though that the corrosion and slightly loose terminal could be the problem? From my limited mechanical memory, it seems to me that a vehicle will still run on a bad battery but not a bad alternator. Is there an instance where the vehicle will not run on a bad battery?
Thank for any help offered!
Modified by masbirdies at 10:59 AM 3/15/2008
