dingofarmer »
https://forums.nicoclub.com/dingofarmer-u48272.html
Tue Oct 03, 2006 7:41 pm
I was so happy when I fixed it that I had to open an account,this thread helped.
Ok so I washed to engine bay to get rid of alot of oil from seals and gaskets that I replaced. Went on with my day and around lunch, noticed that my brake light was solid. Never heard the buzz, cause I was jamming out.
Got home and went inside. About an hour later I went to start my car. It started but then stalled, tried it again, same thing, this time I pressed the gas for a few seconds and it stayed running, but was running funny, and the brake light was solid and the bat light was dim. Drove it around the block thinking that the bat was low. The bat light would only come on after an annoying buz from the dash, followed by the solid brake light, they would then go off, and cycle every few seconds. Came home and restarted the car, still stalled. Opened the hood and looked around. The o2 sensor braket was off of the header and the wire was laying on the header. Oh crap, I looked at the wire and it had melted some of the insulation. I left the car alone, as I had a meeting to go to.
The next day, I cleaned the bat terminals, as they were a bit corroded, reatached the braket with a new bolt and reinsulated the o2 wire and checked to make sure that it was connected. Looked around and traced a few wires also. Started the car, and it worked, however when I tried again, It stalled. I got it running and drove to advanced auto and had the bat and alt checked. 72amps, bat good. Weird.
Got home and pulled most of my hud out and panels thinking that maybe, there was something arcing. I finnaly got tired and decided to do a google search, finnaly got to this thread. I then went out and started going through my fuses, which for some reason I overlooked,frustration. Eng Cont 10A, was blown. Replaced it and voila, it started perfectly, no lights or weirdness. What I think hapened is that the preasure of the water was enough to knock off the aready loosened O2 bracket. THe header melted the wire just enough to make contact with the lead, which probably blew the fuse.
I overlooked it cause I had tunnel vission about some mysterious wire causing the problem.
John
