Ron Burgundy wrote:Bump...
Also, what makes the positive cable so difficult?
If you wanted to run the new cable in the factory cable sleeve (even though there really is no reason to) then you would have to remove all of the wire sleeve and electrical tape all the way from the battery to the alternator. The recommended method would be to just run new cable outside of the factory cable sleeve. It wouldn't be too difficult, just a PITA.
The negative cable is comparatively much easier since it's just held down by two bolts and a zip-tie. It took me maybe ten minutes to completely remove the negative battery cable (assuming it's the same setup on the 3.3L).
As far as your positive cable pics, it doesn't actually look frayed or broken, just a little oxidation. Just clean off the oxidation and wrap any exposed cable in high-grade electrical tape (or liquid electrical tape).
