3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Sat Jan 17, 2015 7:56 pm
yeah, i had one get ever so slightly loose on the pass side of the fgy33 a couple years ago.
it would click when turning, yours is absolutely a safety concern, please fix it right away.
that collar is the only thing holding the strut piston into your strut cylinder.
And holding the strut in the cylinder keeps your spring under tension even when the assembly is removed from the car.
I was able to tighten mine by raising that corner (so the coils would spread), and getting a pipe wrench in between the coils to tighten it.
it should be quite tight (50 ft-lb+).if your nut is already backed all the way out, then try to thread it in several threads and get it at least finger tight.
so the spring doesn't completely unload and blow a hole in you as it frees itself when you raise the car.
look for an old post from me around march 2005 if you want some pix on how to actually change the struts.
