Ball Joint / Control Arm? Suspension Problem? Video included
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
uLikeMyG35x
Car: Blue Slate 2008 G35x
Completely stock, for now...
Dear Readers,
I have a been a long time reader, far before I even purchased my G35X several months ago.
Please check the videos out, the sound will be apparent and emanates from the driver side wheel. The steering does not shake.
Links to videos:
https://youtu.be/YWpkHTFCYqM
https://youtu.be/2DGjATQKGX0
Any help would be appreciated before I bring it into the stealership, or hopefully find a good local mechanic. Regardless, I'd like to have somewhat of an idea of what the diagnosis will be, before I bring it in.
Again, I appreciate any advice / help.
BTW, have really enjoyed my G so far, it has close to 85,000 miles.
PapaSmurf2k3
Site Admin
Almost sounds like a bad tire or loose wheel.
Have you jacked the car up and tried to rock the wheel back and forth both vertically and horizontally? If you have movement horizontally, it usually means a bad tie rod end or bushing somewhere. If you have movement vertically (pushing inward towards the center of the car on the top of the wheel, pulling outward towards yourself on the bottom, and alternate), it means you have a bad wheel bearing.
Also check the torque on your lugnuts.
Welcome to NICO!
uLikeMyG35x
Hey, Thanks for the warm welcome.
Oh, I hope its just a some loose lug nuts.
Will post a reply when I find out for sure though...
PapaSmurf2k3
Site Admin
If they ARE loose, and you've been driving it like that for a while, you'll probably want to go ahead and replace all the wheel studs. I'm sure they've been damaged/stretched if that's the case.
uLikeMyG35x
Yea, I'm going to have someone with some more knowledge take a look at it this week.
In the meantime, the Sentra will see some daylight.
Will post more later this week.
Thanks
uLikeMyG35x
Hi,
So it turns out the problem is a bad / worn out wheel hub assembly.
I plan to have this replaced by a mechanic, so now the search begins for the best price.
Fortunately, I have an alternative backup car.
Thanks for the input! :)
PapaSmurf2k3
Site Admin
BAM! Wheel bearing.
I forgot to mention, if it gets worse as you load that side of the car, and goes away when you unload it (like when you're turning the opposite direction), its most likely a wheel bearing.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
