kevindanielk »
https://forums.nicoclub.com/kevindanielk-u42212.html
Sat Apr 19, 2014 10:59 pm
Stefan, I need some clarification on what exactly happens when you try starting your car....does the key cylinder turn all the way to start or is the key cylinder sticking and not making it to the crank position? If it sticks, you need a new lock cylinder. If the key is making it all the way to crank, right where it used to always start at, but no starter turns, then what you most likely need to replace is the electrical switch portion that's screwed into the left end of the key cylinder. That switch basically brings all the ignition, accessory and starter wires into contact with 12 volts, as you turn the key. Those switches are a weak point, on just about all the Nissan vehicles that I have owned. The solder contacts inside those switches go bad and cause all kinds of trouble, like not allowing current to flow to and crank the starter.
I also just thought about what if the starter relay is going bad, not 'relaying' the ignition crank signal to the starter. Those relays, when going bad, allows intermittent starting until they totally fail. Possible also.
