As we all know, the stereos in the G37's need a bit more bass. I didn't want to spend a lot of money on a system like my previous Infiniti, so I decided to go with a powered subwoofer. Rockford Fosgate makes a new sub in an enclosure and a 300watt amp called the Overload. (there is another NICO member with the same setup) I was going to install it in my garage, but I decided to have a shop do it to spend the day with my family. So I called up the same shop that did my window tint and made an appointment. I also had a few bubbles in my tint that I wanted to have them fix.
So I drop off the car with the owner and we went to lunch/shopping for a few hours. 3 hours later, we went to check on the car. The owner said they had to "take a pass" on the job. They couldn't find a way to run the power wire from the engine compartment. Total BS. Wouldn't have been that bad, but they didn't call to let me know to make other arrangements. So I check out the equipment, to make sure everything is there and find a few scratches and a large gash on the side of the subwoofer enclosure. I asked the owner to come out and take a look...he denies that they did it and walks away acting like he did me a favor by replacing the tint, which was under warranty.
If you're in the south Atlanta area, do not use this shop!
http://radioactivecarstereos.com/
A guy I work with used to be a stereo installer so we'll hit it next weekend.
