Hello,I have a 1988 Nissan Maxima, I replaced the drive axles, both R & L. The Left axle didn't go in smoothly, pushed it couple of times then I had to pull it out and re-inserted again, went in and locked by the circlip.
Nowwith shifter in PARK, R axle is locked, Left is moving, cranked the engine several time, id did not rotate but was not locked, then the R axle didn't lock as well.
Checked cable adjustment for the shifter, didn't help. Starter works in both positions, P & N.
What is the next step, remove and re-install both axles ? would it change anything, Please advise, thanks
