My favorite thing in the world. Transmission issues.As stated in the title, the car's my 1993 Maxima GXE.The car was stuck in third gear for a while tonight. But only for a while. After I turned the car off and restarted it, it went back to normal.
I have no idea at what point the car became stuck in third (I say third, which is merely a guess, because of where RPMs where and things. I doubt it was 2nd as I was doing 75 without overrevving. I know it wasn't fourth because I passed a guy at 50mph and had plenty of torque. I actually noted to myself that it was pulling a bit harder than normal at that speed. That's when I hit the overdrive switch--thinking it was turned off. It wasn't. Hitting the switch made no difference in rpms. Neither did moving the shifter to "1" or "2".
Then when I got off the freeway, I stopped at a light. When I started off--that's when I realized what was going on. It was stuck in (I'm guessing) third gear. Very sluggish, revving too high for the rate of acceleration.I hit maybe 3 or 4 more lights on the way to the office (where I figured I'd park and check things out since it wasn't far) and every time it was the same.
When I pulled into the parking lot I was careful to test that reverse was working before pulling into my spot. Reverse worked fine. But when I put it back in "D" (or "1" or "2") it stayed in 3rd.
So I parked, turned the car off, and started it again. The start sounded a LITTLE bit harsher than normal. But I probably only even noticed that because I was paying such close attantion to things at this point. I reversed out of the spot and put it in "D". This time it went into first as it should have. Since it was wet, I gave it a little "goose" and the tires spun. Definitely first gear.
I checked my trans fluid. It was right in the middle (a bit high for "cold" but a bit low for "hot"). The transaxle was not hot--I could remove the trans fluid dipstick with my bare hand--which I can almost never do without waiting for the car to cool a while. The fluid is still bright red--only has maybe 20k miles on it.
The transaxle was rebuilt at about 178k miles. The car now has 203k miles on it.
At no time did I ever see a CEL or any other dashboard indicator light up.
Any input on this would be appreciated--I was planning to drive this thing to the Phoenix meet this weekend--for which I leave thursday morning.
