Re: (300hp owen)
Postby rsagen » Sat Apr 10, 2010 9:46 pm
300hp owen wrote:I dont think so but that would be awesome if you could. I bet a lot of the parts are identical (clutch release fork, tailshaft cover, etc)
it wont work, trust me I have tryed. the truck tranny is 3 inches shorter. seems like a peice of cake if you get a driveshaft extension, but then trying to figure out what to do on the shifter.....
as for the flywheel and clutch and everything.... the truck has a 1 inch bigger diameter on the flywheel and the clutch, therefore being heavier. its also 30 bucks cheaper at NAPA for a new clutch kit.
with the truck flywheel and clutch on my car tranny (bolts together just the same) I think its pretty well impossible to stall the car. I can almost drop the clutch in 1st without it stalling with no revs
Quote, originally posted by PoorManQ45 »"Bah, no need to run antivirus.Just reinstall windows every month"
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
Re: Auto to Manual Writeup (5 speed conversion)
Postby jerry130891 » Fri Apr 30, 2010 5:13 am
Hi, I am just going to swap tranny to my 98 240sx, and i saw this thread a couple months ago... but i just enter again, and all of the pics disappeared, can someone help me with this?? I realy could use this info to make the swap correctly.. thanks!
jerry130891
Car: 1998 Nissan 240sx LE
Postby jerry130891 » Mon May 31, 2010 7:30 pm
please... I really need it... the pics are a huge help!
jerry130891
Postby FusionR300zx » Mon Aug 02, 2010 12:06 am
where did the pics go? i need them.
FusionR300zx
Car: 1993 300zx/1997 240sx
Postby jerry130891 » Mon Aug 16, 2010 2:04 pm
FusionR300zx wrote:where did the pics go? i need them.
+ 100000000
jerry130891
Re:
Postby JDMskrilla » Fri Nov 19, 2010 7:26 am
obg3506 wrote:Anybody figure out the Cruise Control!!!! I need it bad, lead foot!
I had the same problem but it was because I had the wrong speed sensor. I had the s13 speed sensor and it was causing my spedo to read double. well cruise control wont work under like 30mph or over like 90 or 100mph (not sure on the maximum, never tested it). Anyways as soon as i got the right sensor the cruise control started to work so now when I'm going 60mph it doesn't read 120 and the cruise control works.
JDMskrilla
Car: 1997 240sx se
Postby love_my_s14.5 » Fri Feb 18, 2011 4:46 pm
Hey guys I'm about to finish up my swap.....all I need is to inject the 5 speed into the motor.....and well none of my automatic connectors fit on my OBDII transmission except for the CAS and I was wondering is that all you need to at least drive the car.......PLEASE LEMME KNOW
love_my_s14.5
Car: 1996 240 SE with S15 front end----current
1995 240 with kouki front end----totaled it=(
Postby MyNISMO314 » Sat Mar 05, 2011 3:40 pm
bought a car with a 5 speed swap already in it...the problem i got is the guy put the factory bleeder hoses and all and now my clutch gets stuck in when i push it in and today all the damn fluid leaked out...did you bypass that factory stuff somehow or what...i tried adding more fluid and pumping the clutch but looks like the hose had enough and it just keeps leaking out...i was told i can bypass it but i asked the guy how and still hasnt answered so trying my luck here
Sorry, animated sigs are not allowed
Buffalo Wild Wings - DAS IS VERE WE LIKE DO DRINK ZE BIERS UND EAT ZE VIINGS
MyNISMO314
Car: 91 SE Coupe w/red top sr20det(currently for sale)
Postby moso » Sat Mar 05, 2011 3:51 pm
even if you bypass the clutch dampener you still need that rubber hose that goes to the slave cylinder. buy a new one or buy a braided clutch line.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
Postby MyNISMO314 » Sat Mar 05, 2011 4:01 pm
moso wrote:even if you bypass the clutch dampener you still need that rubber hose that goes to the slave cylinder. buy a new one or buy a braided clutch line.
so my only problem is the clutch line? ive looked on here to which one it is but cant find it
MyNISMO314
Postby moso » Sat Mar 05, 2011 8:56 pm
I cant say "that is your only problem". i can say "if your trying to bypass anything in the clutch system the only thing to bypass is the clutch dampener". i can also say "if your bypassing the clutch dampener and the rubber hose is leaking you need to replace it or change out the entire line to a braided hose" but that really depends on how much loot you want to spend. i can also say "if your having trouble with your hydraulic clutch its best to replace both the master and slave at the same time because they are so cheap" however that is a matter of opinion.
moso
90 240sx ka24de RIP
Postby MyNISMO314 » Sat Mar 05, 2011 11:47 pm
yea ive seen circuit sport and couple of others have a 52" braided steel line the goes all the way from the MC to the SC and i think i will replace both cylinders as well just to be on the safe side and because they are cheap as well...but thanks for your help i tried looking around more and had no luck. :dblthumb:
MyNISMO314
Postby driftneil » Sun Mar 06, 2011 9:46 am
Its simple bro...Just get the auto to manual conversion braided line from "FR sport" (or any place) And that goes right into the slave...So that takes care of your split rubber hose, and also deletes the dampener.
Then all you need to do, is attach the line to your master, but not the slave...Fill the master, and have a friend keep it topped off. And point the slave end of the line at the ground till it pours fluid. Attach to slave, and boom done. No need to bleed...USUALLY.
Good luck
Oh...Push the pedal to the floor, as well.
"If your not first your last" trademark of Ricky Bobby.
91 and 95-240's for sale...http://forums.nicoclub.com/zerothread?
driftneil
Car: 97 se, and 3-95 240sx's
Postby mattaltima99 » Fri May 13, 2011 5:47 pm
Is there a difference in the auto and manual drive shafts? Cant you use a s13 auto drive shaft with an s13 5spd tranny?
mattaltima99
Car: 1999 Nissan Altima KA24DE, Spectra Cold Air intake, OBX 4-1 Headers, OBX 10.36 Spark Wires, Flowmaster super 44
Postby thienthan » Mon Oct 10, 2011 5:47 pm
Can I use a s13 manual drive shaft for a s14 5 speed conversion with no abs?
thienthan
Postby diggles240 » Fri Oct 14, 2011 10:45 pm
^ nope
^^ nope
the FSM has the 1st and 2nd shaft lengths [spider to spider] that will show you the difference in length per model, ABS, etc.
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
Postby stuart003 » Tue May 08, 2012 6:19 pm
How did u manage to only spend 400 to 500 $$$ on parts/tools?
stuart003
Car: S14
Re:
Postby PHRINCE_S14 » Sun Aug 05, 2012 12:25 am
Fam0uZ wrote:Im new here and im doing the A/T to M/T conv. following this write up but i have some questions.
1.what would happen if I dont swap to manual ECU??2. I have a 95 Se which comes with ABS but the driveshaft that i found its a non-ABS is that going to give me any problems? 3.Can i buy the m/t bolt in a hardware store?b/c in miami there are about 12 junkyards and 0 s14 in them lol
Modified by Fam0uZ at 10:35 AM 9/10/2008
As stated above the write up: CEL readings would always pop up, and you need to get an ABS driveshaft because your car is an SE model.. And I'm just curious about those wheels on that Zenki. What kind of wheels are those? would also like to know the sizes and offsets. thanks :laugh:
PHRINCE_S14
Car: Drives a 95 S14 ZENKI
Postby S14Magician » Fri Sep 28, 2012 11:42 am
okay so ive researched this in a few places and would like a confermation i have a 95 obd 1 s14 ive pulled everything for my swap from a s13 ive read that all the parta will work on my car true or not. non abs
S14Magician
Car: 1995 Nissan 240sx
Previous
Return to 240SX Technical Forum
