MCNPathfinder wrote:My friend has a Ford Expedition with auto 4wd which is kind of the default mode apparently. He was having this weird thing where the 4wd would kick in and kick off every once in a while while driving in normal conditions not slipping around and stuff you know? Does that sound right?
How does the Nissan system work? It snowed really heavily last night, so I was thinking about taking it out of 2 and popping it in Auto, but I wanted to make sure I wasn't going to damage anything. See, I always have it in 2, and my rear tires are more worn than my front tires. I don't want to burn anything up by thinking it's slipping when it's not. When I turn it to Auto the 4 little green tires on the dash light up, but it still feels like it's in 2, will something else pop up there when it kicks it in 4 then? Or do I not really know when it's in 4 vs 2 in Auto?
Couple of things: If it's in 2WD, it will not engage the front wheels, no matter what the driving conditions (unlike your friends' Expedition).
Going into Auto 4WD doesn't mean it's powering all four wheels all the time either. It only delivers power to the front wheels when needed (like 01 silvapathy says). You can switch in and out of AWD while moving with no problem.
Personally, If the weather is looking a little iffy (rain, snow, etc), I run Auto 4WD pretty much all the time. Never had a problem.
BTW, that's what these trucks were designed to do, so why you would think that you would damage anything by running AWD is a mystery to me. Oh well.
The only thing not recommended is running it in full time 4WD on dry pavement. That can cause undue stress on the system, especially when cornering.
