okay so I've ran into a pretty major problem. Ive installed and ran the front woofers and tweeters into the cross overs and wired that all the way back to the trunk (both sides). I also installed the rear speakers (i was shocked how how complete garbage the stock ones were in comparison) and wired that. Now at the trunk I have all the wires I need to hook up to the amplifier, BUT I have one problem...... the head unit doesn't have RCA's to go into my amplifier....
I've done alot of searching and found some threads but it wasn't answered. The back of the stock head unit looks like this,
If you have any idea on how to hook up an amplifier to the stock head unit, PLEASE, inform me.
I brought it to a near Audio shop and they sold me a $20 harness which apparently tells me what wires are which. (example: 3rd white wire over is Left Front speaker (+) and 4th black wire is Left Front speaker (-) .....) Now From what I understand I'm supposed to CUT, the wires as they come out of the head unit and attach them to my own wires and run it back to the amplifier and hook them up into a 8 wire plug that came with my Amplifier.
This is my poorly drawn example. Gray = the crimp .. Red = wire I insert, and the yellow/blue wires are just my attempt of drawing the wires coming from the head unit extended.
I REALLY don't want to screw anything up (cutting wise) and have to bring it to the dealership to get a whole new wiring harness put in because I acted and didn't research. Thanks for any help!!
