ace rothstein 81 wrote:The guy I talked to yesterday at a local car audio shop said the best thing was to disconnect the factory tweeters because they are two far away from the front speakers. The ones they are going to put in are directly on top of the new speakers in the front door and can be "aimed" so to speak. I'm not an audio guy, so I don't know if I said all that correctly, but whatever...
I'm no audio 'expert', but I am a hobbyist, and I'm dubious of any audio "expert" who'd want to lower the tweeter to the door in the Versa. Countless cars, some with fairly high-dollar factory systems, have the pillar-mounted tweeter with the front woofers at the bottom of the door panel...moving the tweeter doesn't make sense for a few reasons.
First off, you want your speakers at ear-level, if possible. In home theater audio, speakers should be mounted such that they are ear level when you are in your seated position.
Higher frequencies are attenuated (quieted) more dB per unit distance than are low frequencies...that is, high frequencies don't "travel" as well as low frequencies. That's partially why bass carries so much better from a passing car than their treble (also because they have the bass turned up so much more than the rest...but it still applies). (This is a basic principle of audio theory that I deal with when using seismic surveys in my line of work...)
So, having the tweeters at ear level would ensure that the shortest travel path from speaker to ear is achieved, whereas relocating the tweeters to the door panel would increase the travel path, thus quieting the treble moreso than the lower frequencies coming from the door woofer.
So if he's complaining about the treble lacking in his Versa, the last thing I'd do is increase the distance from my ear to the tweeter. Probably all he needs is an aftermarket tweeter with better specs.
