General discussion area for the Altima Coupe. Sponsored by: Racingline Performance
Audi style Ribbon LED on A/C
Postby Anstability » Sat Nov 22, 2008 4:14 pm
I saw someone do this with a 19" flexible LED strip, but I didn't think it would fit with stock bumper, so I bought the ribbon LED strip from oznium.com and put it flush under the headlights. althought I bought "cool white" looks too purplish for me, I'm kind of dissapointed with the color. Anyways, Installation doesn't require you to you remove the bumpers, just slide them in and hard wire it to a 10A minifuse from your fuse box. i used the "clearance lights" fuse so It would turn on with the light switch.
This is my first post, but I've been looking at this forum alot (especially at work ) Thx to everyone who's advice I've used.
Modified by Anstability at 9:33 PM 11/22/2008
Anstability
Re: Audi style Ribbon LED on A/C (Anstability)
Postby imdavit » Sat Nov 22, 2008 4:26 pm
that looks crazy, need some daytime pics also if u get the chance.
nice work!
Radiant Silver 08' Altima Coupe 2.5s
5% Rear 35% Front Tints ~ Debadged ~ Xentec 6000k ~ HIDs Eibach Pro-kit ~
Nismo Exhaust ~ Painted Tales ~ BlueBat's 60% GT-R Headlight Overlays ~
Stillen RSB ~ Fujita WAI ~ Racingline Front/Back Endlinks ~ Sentientbydesign's Grounding Kit ~
Xenon Chrome Corner Bulbs ~ Racingline Front STB(black)
imdavit
Car: 08' Radiant Silver Altima Coupe 2.5s
Re: Audi style Ribbon LED on A/C (imdavit)
Postby JVLeGa » Sun Nov 23, 2008 2:23 am
Def. digging those. I hope cops wudn't pull you over for those, esp. if they look too blue, but i think blue is the hottest. Pure A W e S o M E
JVLeGa
Car: 08' Precision Grey 2.5 Alti Coupe w/Premium Pkg.
Re: Audi style Ribbon LED on A/C (JVLeGa)
Postby dangeris » Sun Nov 23, 2008 2:55 am
Looks hot man! Great Job. Post up pics of where you mounted the strips on the headlights.
BTW, the LED flexible strips does fit between the headlight and stock bumper. Someone here has already done it.
2008 Altima Coupe 3.5 CVT, Stillen Front Fascia, Rockers, Hood dampeners, Racingline FSB & RSB & Endlinks, Fast Intentions Cat-Back, G35 deck spoiler, Injen CAI, CF Dash Kit, LBC GT-R Overlays; BC Racing CoilOvers, XXR Type006 wheels, Kuhmo Exsta, 7 Point Ground Upgrade, AP Racing BBK & Rotors
*** Updated Modification List ***
***CarDomain Page***
Click on the Car GIF below to see a larger Pic
dangeris
Car: Code Red 3.5 CVT
Postby spockrock » Sun Nov 23, 2008 6:54 am
can you show us how you wired it up please??
Red 3.5SE Altima Coupe Premium Package: 35% & 20% tints, Racing Line Front and Rear End Links; Eibach Proline Springs, Work Emotion XT7's 18x8.5 +38 w/ Falken 452 245/40/18 tires (summer), Steelies w/ Hankook winter ipikes 215/55/17 (winter), The Doc's Illuminated Kick Plates Red/CF, Projector Headlights, Fujita SRI
Prototyping; Y-Pipe.
Pics Coming Soon
spockrock
Car: Altima Coupe 3.5se
Postby Anstability » Sun Nov 23, 2008 8:12 am
I'll post some pics when i get home later today. It's not really that bright, my iphone camera sucks so it creates all that glare. I'll use a real digital camera when I get home.
Anstability
Postby Kanard » Sun Nov 23, 2008 12:38 pm
^wow, some1 saying something on apple, sucks?! wowoow.. lol ahha but i like that, i want that. can i have that? lol
Kanard
Car: 2008 Nissan Altima Coupe!
Postby toxik » Sun Nov 23, 2008 12:58 pm
looks amazing, good job
09 370z Pearl White - touring/sport
toxik
Car: 09 Pearl White 370z
Postby Rmuth25 » Sun Nov 23, 2008 1:11 pm
Looks great, but seeing that ugly yellow turn signal takes away the beauty of it. Then again there is some glare so I am sure it looks alot better in real life.
"You have to block DeMarcus Ware in the running game, and I am not quite sure Steve Smith(Giants WR) is the answer" - -John Madden
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
Postby Anstability » Sun Nov 23, 2008 1:21 pm
Alright guys, I had some chance to open it up and show the wiring of it.
This is an overhead shot of the headlights, notice there is an orange strip between the bumper and the lights, thats where I slid in the LED ribbon, fits pretty perfectly.
Now, you're going to want to wrap up your connectors pretty good so it doesn't get wet, and run it up the corner, leading to the hood (left side of this picture)
Now, install it for both driver and passenger side, when you have those ready, run the passenger side wires to the driver's side, where the fuse box is. I tapped the positives together and the negatives together to keep things neat.
Now, look the the left side of the picture, I have my needle nose pliers gripped on the "clearance lights" fuse. you can choose whatever fuse thats 10A you like, but this particular one would make your LEDS come on when your yellow DRL lights are on, or when your headlights are on. PULL This fuse out CAREFULLY, its hard to pull it straight out, so get an angle and pull the sides.
(this picture is upside downs BTW)
that little red fuse has 2 sides to it, each with a little hole exposing the contact underneath, it'll be enough for your to solder through the top of it, do so and attach a wire to it. (or you can buy minifuse taps)
Now plug that little fuse back in and twitsy it good with your 2 positives from the lights, than wrap that **** up real good with electrical tape.
Now all you have to do is twitsy up you negative ends and connect it to any Nut in the car (since all metal nuts work as grounds). Clamp it under a nut that isn't exposed to water.
Turn on your lights, test if it works, if it does, find clean ways of running the wires from your passenger side lights over to the fuse box (avoid any hot areas or the hood clamp). to be safe, I wrapped all my **** up with electrical tape, it also makes it look cleaner also.
Here are some finished product pics, it's a pretty moddest mod, barely noticable so I don't think cops will pull you over. I do suggest that you get "neutral white" LEDS instead of cool white, unless you light purple lights on your car. I bought 3 foot worth of ribbon LEDS, and cut every 21 LEDs, leaving you with about 8 inches of strip left over.
Modified by Anstability at 3:33 PM 11/23/2008
Modified by Anstability at 3:42 PM 11/23/2008
Anstability
Postby Rob.Vegan » Sun Nov 23, 2008 6:38 pm
Wow under 10 posts and already going for a custom name...
I really like these lights, they are invisible when their off, nice choice
Click on car pic to see Mods list
Get your LBC Head & Tail Overlays HERE
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
Re: Audi style Ribbon LED on A/C (Rob.Vegan)
Postby HuyyNguyen » Sun Nov 23, 2008 7:10 pm
wowzers..very sexy
HuyyNguyen
Car: Nissan Altima Coupe 2.5s
Re: Audi style Ribbon LED on A/C (HuyyNguyen)
Postby kuhan » Sun Nov 23, 2008 7:27 pm
very nice job. are these flexible led light waterproof and weatherproof?
08 Nogaro Red 350Z Enthusiast 6-sp
kuhan
Car: 2008 350Z Enthusiast 6-speed
Re: Audi style Ribbon LED on A/C (kuhan)
Postby maxentropy » Mon Nov 24, 2008 10:30 am
kuhan wrote:very nice job. are these flexible led light waterproof and weatherproof?
I am also interested--
maxentropy
Car: '08 Altima Coupe 3.5SE
Postby Anstability » Mon Nov 24, 2008 10:39 am
Ty, Yeah, its the "ribbon LED" at oznium.com. It claims that they are water/weather proof just like the thin LED strips that other members have put on their bumpers.
Anstability
Postby kuhan » Mon Nov 24, 2008 11:46 am
thank you for replying.
Is this the kind you bought?
http://www.oznium.com/thin-waterproof-ribbon
Modified by kuhan at 4:03 PM 11/24/2008
kuhan
Postby Anstability » Mon Nov 24, 2008 8:37 pm
Yeah, I bought the cool one, I suggest you get neutral.
Anstability
Postby Sparktree » Mon Nov 24, 2008 9:12 pm
After you cut the ribbons, how do you connect the wires? Specifically, what connectors did you use? With christmas rolling around, and with the recent rsb sale, I only have enough $$ for cheap mods for a while. I am planning on doing the Audi style Ribbon mod and the footwell mod but I am not so bright in the electrical world. Looks so nice~ Can't sleep until I click the buy button.
Altima Coupe 2008 3.5L Shift_Silver
Sparktree
Car: Altima Coupe 2008 3.5 SE MT
Re: Audi style Ribbon LED on A/C (Sparktree)
Postby Anstability » Mon Nov 24, 2008 11:23 pm
You just solder it on, they sell solder irons at radioshack for $8. I taped it up tightly afterwards with electrical tape, but some people suggest using silicone.
Anstability
Postby Sith LL_Coupe » Tue Nov 25, 2008 1:23 pm
Those look REALLY good!!
I think I may just have to try this out for myself during the winter downtime.
Can you post a pic of how you ran your wire from your passenger side to your driver's side for the fuse box. I'd like to know how clean it looks inside under the hood.
Mod in progress: LBC 3/10 Tail Overlays, Nismo 19" Maxima Gunmetal rims
Sith LL_Coupe
Car: Precision Grey Altima Coupe 3.5 SE CVT (Prem. & Tech. Pkg.)
Re: Audi style Ribbon LED on A/C (Rmuth25)
Postby psychoffspring » Sat Nov 29, 2008 6:18 pm
have you ever been pulled over because of the LED strip? and wat state r u in?
2008 Altime Coupe 2.5L Winter Frost
North NJ owner
psychoffspring
Re: Audi style Ribbon LED on A/C (psychoffspring)
Postby coderedk » Sat Nov 29, 2008 7:21 pm
ok im but to order these, what exactly did you order? how many feet should i buy
coderedk
Re: Audi style Ribbon LED on A/C (coderedk)
Postby dl_yeunuoc » Sat Nov 29, 2008 9:15 pm
Another idea
dl_yeunuoc
Car: altima coupe
Postby LongBeachCoupe » Sat Nov 29, 2008 10:11 pm
NICE!
Welcome!
LBC Overlays are HERE! INSTOCK & $32 DELIVERED!
20" ADR Propulsions-SurmanM Custom Dash Cluster -Racingline Front Strut Tower Bar-SBD Grounding Kit-Stillen Lightweight Pulley-Stillen RSB-Xentec Heads n Fogs- Chrome Signals -Fiberglass Eyelids - Eibach Pro-Kit- Fujita WAI - Nismo CatBack - 15/5% tint - Red LED Interior
LongBeachCoupe
Postby johnd635 » Sun Nov 30, 2008 5:00 pm
How did you actually keep the led ribbon in place? Looking at my car, I see the gap between the headlight and the bumper, but I don't see anything behind the gap it to stick it to. What keeps it from falling inside the bumper?
johnd635
Car: Altima Coupe 3.5SE Super Black Premium
Re: Audi style Ribbon LED on A/C (johnd635)
Postby Anstability » Mon Dec 01, 2008 5:54 am
I ordered 3 feet worth of lights, they come as 1 long strip, and then you just cut them.
Although there's nothing behing the gap between your bumpers and lights, the deeper in you get, the tighter it gets, so it doesn't really budge past the 1st cm (you might have to push a little to get the strip in because of friction), If you want to be sure, you could always take off the bumper and use the adhesive bottom to position it in place on the bumper.
I drove by a few cops here in WA on small streets and none of them seemed to mind, although I was pretty scared doing so...
Anstability
Postby ESP » Mon Dec 01, 2008 12:06 pm
Lookin' good! I was worried about the 5-0 pulling me over for them too, but I've haven't had a problem with them so far. One time that I was pulled over (for an entirely different reason) it was starting to get dark out but I didn't have my headlights on (only the LED strip) and the cop said nothing about it. I think that as long as they're white they can't legally do anything about it.
ESP
Car: 2008 SexyBlack A/C
Re: Audi style Ribbon LED on A/C (ESP)
Postby johnny_d » Mon Dec 01, 2008 1:42 pm
i got the Stillen bumper and there is definitely a gap for this but i was wondering can this be done w/o removing the bumper? i'm kinda lazy/scared to remove the bumper hehe
Mods: Injen Intake, Stillen Cat-Back, Stillen Fascia, Stillen Hood Dampers, Eibach ProKit, RH R7 19s w/ FK-452s, 35/20% tint, LEDs.
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
Re: Audi style Ribbon LED on A/C (johnny_d)
Postby maxentropy » Mon Dec 01, 2008 2:17 pm
johnny_d wrote:i got the Stillen bumper and there is definitely a gap for this but i was wondering can this be done w/o removing the bumper? i'm kinda lazy/scared to remove the bumper hehe
If you followed Stillen's included instructions you wouldn't have sag. It's due to a piece from the OEM bumper that was removed that should have stayed to give support to the Stillen Fascia.
I made sure my shop understood that most shops forget to keep that part in there, and they left it there on mine. I have no sag at all. The sag stories is what kept me from buying the fascia in the first place, but not I am VERY glad I did-- I get comments all the time!
maxentropy
Postby losenone » Mon Dec 01, 2008 2:34 pm
Awesome job!
Quick question for everyone, since im not really sure. I have the LED Strip mod done, same as ESP. You think both would be a bit tacky or no? I cant decide
losenone
Car: AC 3.5 CVT K12
Postby D-Roll » Mon Dec 01, 2008 2:37 pm
Looks real good bro, GREAT job!!
D-Roll
Car: 2008 Nissan Altima Coupe 2.5S 6MT (Dark Slate)
Postby Anstability » Mon Dec 08, 2008 11:34 am
You go neutral white ESP? Man... I still get chills driving by cops with the cool white.
Anstability
Postby 3ugene » Mon Dec 08, 2008 2:58 pm
Dont know why this particular thread has been so popular, its been done before in both the sedan and A/C forums. Personally I think it looks cheap. If it were inside the headlight though, that would be sick. But for the price of this compared to a retrofit, I guess itll suffice.
19" Volk GT-S w/ Falken 452
Fujita Intake
Racingline everything (F+R links, strut bar)
Stillen underdrive pully+RSB
5% tint in back
Grounding Kit
BC Racing BR-Type Coilovers
Stillen Rear Roof spoiler
Ebay "CMOD" Grill
Dual Projectors coming soon (:hopefully: , step on it Brandon!)
3ugene
Car: 2008 Altima Sedan 3.5SL
Postby ESP » Mon Dec 08, 2008 4:59 pm
Anstability wrote:You go neutral white ESP? Man... I still get chills driving by cops with the cool white.
Nope...mine are most definitely a "cool" white. I got these ones here: http://www.oznium.com/thin-led-strip
They only have one choice for white and this was it. I wouldn't worry about your local ham & bacon...if they give you a ticket, just fight it. As far as I know, they have no grounds on which to give you one.
ESP
Return to Altima Coupe
