I am having my Megan Coilovers installed tomorrow to fix the weak spring issue on my old Tein lowering springs.
Questions - What did you do ride height-wise? I am hearing that the out-of-the box is 1.5" lowering, the Tein's were 2". I am thinking of taking the 1/2 raise to get a little bit off the ground.
How hard is it to change ride height after you do the install??
What Spring Pre-Load did you use?? The factory guy I called said leave at 0
Thanks,
