A forum for the Nissan Armada and Infiniti QX56.
Armada gas mileage
Armada gas mileage
Postby Pumaro » Sat Dec 31, 2011 7:56 pm
What kind of gas mileage should I expect?
Does the gas mileage improve after the car is broken in?
2012 Armada Platinum (Lakeshore Slate)
2007 335i (Monaco Blue)
Pumaro
Car: 2012 Armada Platinum (Lakeshore Slate)
Re: Armada gas mileage
Postby nissangirl74 » Sat Dec 31, 2011 9:24 pm
In city 12-13, highway 18-19. It won't get any better but it can definitely get worse if you don't stay on top of the maintenance.
Follow NICOclub on Twitter!
Friend us on Facebook!
Bella!
krash wrote: We just stay here hoping and praying that she'll start jogging again, but she keeps trying to convince us that we want a fat FWD chick with CVT.
nissangirl74
Car: 2013 MazdaSpeed3, '00 Honda Insight, '05 Frontier, '77 620, '72 240Z w/RB25, '68 510, '67 WRL411, '67.5 SPL 311, '64 Bluebird, '63 NL320, '60 Bluebird
Postby Pumaro » Sun Jan 01, 2012 1:08 pm
nissangirl74 wrote:In city 12-13, highway 18-19. It won't get any better but it can definitely get worse if you don't stay on top of the maintenance.
Thanks for the info, I was afraid to say 13mpg but it looks like thats where its at.
At what speed would I get 18-19mpg on the highway?
In Texas the avg highway speed is around 80mph between Dallas and Houston, I think the computer was saying around 15mpg.
What octane fuel do you use?
Pumaro
Postby nissangirl74 » Sun Jan 01, 2012 6:07 pm
18-19 is the mileage posted by Nissan on their website. Real world numbers are often different. IF you get that much, I would say you would have to have almost no extra weight other than a driver, no incline at all on the road, and be able to set the cruise control somewhere around 70. MPG tends to decrease after 70. As far as octane is concerned, just use what the owner's manual recommends. Using a higher grade than what is recommended will not make you get better mileage.
nissangirl74
Postby Pumaro » Tue Jan 03, 2012 8:03 am
BTW I noticed that the range dropped to 20 miles and then immediately went to *** which of course made me panic and pull into the very next gas station.
I filled up expecting to pump around 28 gallons (the size of the tank) however I could only pump 24.8 gallons.
Is this normal for it to not use the whole tank?
My other cars BMW and Audi would allow me to use the whole tank before reading 0 miles.
Pumaro
Postby Timmbo » Tue Jan 03, 2012 4:12 pm
That is normal on the Armada!
Also, the MPG will improve as it breaks in. I am at exactly 15mpg in mixed driving. The key is to use the cruise control as much as possible. I noticed a huge improvement as I worked my way up to 5000 miles.
I know if you have your cruise set around 65-70 (which I think is a little slow), you would get right around 17-18 on the highway.
2013 Infiniti JX35 AWD (Midnight Garnet / Java) & 2013 Nissan Maxima Sport (Pearl White / Black)
Timmbo
Car: 2013 Infiniti JX35 AWD & 2013 Nissan Maxima Sport Pkg
Postby marctronixx » Sun Jan 08, 2012 1:00 pm
keep RPMS below 2k is the key to getting good gas mileage anywhere. watch the engine load graphic bar when you accelerate, etc.
anything over 55 MPH on the highway will hurt gas mileage.
drive around 65 and you will get some pretty good numbers.
the fuel gauge is conservative. you have a big vehicle and it takes a lot of petrol to power it. its not as efficient as a smaller car which you could drive down to nearly 0. you dont want to get to 0 on this sucker. :)
you have about 5-6 gallons left in reserve when the ** comes on, however if you are lead footing the accelerator pedal when your tank is low, the ** will come on much sooner, so you could have even more petrol in the tank.
marctronixx
Postby Timmbo » Tue Jan 10, 2012 8:38 am
I mentioned it before, but anytime you are on the highway, use the cruise control...........this helped a TON for me!
Timmbo
Postby marctronixx » Wed Jan 11, 2012 11:33 pm
agree tim,
when im on there for more than 2 miles, i turn on the ICC on the Q. then i sit back and relax. 55 to stay alive! :D
marctronixx
Postby Timmbo » Thu Jan 12, 2012 8:53 am
See, that would even be better then what I get for MPG, I set my cruise around 74. I know at one time when they had highway construction going on and the speed limit was at 55, I actually had my MPG reading 18.3. But I was driving like a grandpa and again, cruise set at 55 is ideal.
Timmbo
Postby Pumaro » Fri Jan 13, 2012 12:08 pm
Timmbo wrote:See, that would even be better then what I get for MPG, I set my cruise around 74. I know at one time when they had highway construction going on and the speed limit was at 55, I actually had my MPG reading 18.3. But I was driving like a grandpa and again, cruise set at 55 is ideal.
yikes 55mph ?
The speed limit on I45 from Dallas to Houston is 70mph so most folks move at 80mph but in the Armada it still feels like your crawling. I couldn't imagine 55mph.
Pumaro
Postby Timmbo » Fri Jan 13, 2012 12:37 pm
Yeah, I could not agree with you more! If I am not using the cruise, I catch myself going 80-85 in a 65...............it drives and handles so well and smooth!
Timmbo
Postby marctronixx » Mon Jan 16, 2012 11:24 pm
yeah its easy to get caught up in the rush of traffic. but i have the tunes going and the cruise set. out here in LA the freeways ive bee non are like 65 so 55-57 is not bad. cops are deep out here.
i used to drive no less than 75 mph in the armada when i lived in atlanta (seed limit=70) and would get like 14-15 mpg. i eventually started using cruise and went to like 65 and got better mpg. i had 24 inch wheels plus a CAI, a 2 degree timing advance and a magaflow. those thignts helped also.
but now i drive like grandpa and love it. the RPMS barely hit above 1K :)
marctronixx
Postby EcstaSPT » Fri Feb 24, 2012 8:42 am
08 LE here...12-13 city and about 18 highway
EcstaSPT
Postby Timmbo » Fri Feb 24, 2012 9:24 am
that seems right on, I know during the summer I at 15 overall, and right now in winter (4wd on more) I am at 14.8 overall.
Timmbo
Postby C-Kwik » Fri Mar 09, 2012 12:55 am
Generally, the slower the speed, the better the gas mileage. The largest resistance a vehicle sees at a steady speed is the aerodynamic resistance. Full size trucks have a large frontal area, not to mention a relatively poor aerodynamic profile. The amount of force necessary to maintain a speed if going to be:
F = K * V^2
where K is some constant related to the aerodynamics of the vehicle and V is the speed.
nissangirl74 wrote:18-19 is the mileage posted by Nissan on their website. Real world numbers are often different. IF you get that much, I would say you would have to have almost no extra weight other than a driver, no incline at all on the road, and be able to set the cruise control somewhere around 70. MPG tends to decrease after 70. As far as octane is concerned, just use what the owner's manual recommends. Using a higher grade than what is recommended will not make you get better mileage.
Weight will only make a significant difference in city or stop and go driving. At highway speeds, the change in overall friction from weight is going to be quite small. At worse, a huge load might cause the angle of attack to change slightly and may cause an increase in the K constant, but generally, it won't a make a noticeable difference for steady state speeds.
I usually get about 12-13 mpg in the Titan. The best long range mileage I saw was when my mom borrowed the truck to go to Yellowstone years ago. She got about 15.5 mpg. Not sure what kinds of speeds she saw, but she definitely doesn't do the 80-85 I usually do on the highway.
C-Kwik
Postby C-Kwik » Fri Mar 09, 2012 12:58 am
I should also add that lifting the vehicle and/or using wider tires can decrease economy as well. Both increase the frontal area.
C-Kwik
Return to Armada Forum / QX56 Forum
