Are Upper Link Bushings replaceable?
Meaux
Car: 94Q45, 92Porsche 968, 72Porsche 911, 89Maxima SE, 98Honda Civic, 85F150 w/95 5.0
How hard is it?
I plan on replacing the Tension Rod bushings, soon and I thought, why not just do the bushings on the Upper Links also...Should lower the cost...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You would have to source the bushings first.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Someone said that you can replace the bushings from the Z32, as the Z32 ULs have replaceable bushings... May be wrong though, however theyd likely be poly so you may think theyre too harsh?
However, there are no replacement bushings for the Q45 UL's..
RobertsnewQ
Q45 and 300zx upper links have the same part number.
Anyway, NISMO sells hard rubber bushings for the upper links. That's the only source I know of.
The problem? They want around $20 for EACH bushing! That means that a set of eight of the suckers will cost as much as a new pair of upper links.
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
Not only will the replacement bushings cost as much as new upper links, but removing the bushings is not going to be fun.
You cannot simply burn them out like other bushings on the car. There is metal inside and I think a bearing also. So they would have to driven out from behind.
If you do go this route, please let us know how everything went.
Meaux
sijoko says, "If you do go this route, please let us know how everything went."
I'll admit, I am Crazy, not Insane... :-)
elwesso
2007 BMW M Coupe
new upper links are $100 each, but is it worth the risk? maybe?
id ask some Z32 guys and ask them what they do... still i think itd be easier to find a lightly used set of adjusties like mine..... I paid MUCH less for my adjusties
Flagship-Q
Car: 1992 Infiniti Q45
So going the adjustable route you can just replace the bushings when the get worn out? If so, seems like the way to go for sure!
elwesso
2007 BMW M Coupe
Flagship-Q wrote: So going the adjustable route you can just replace the bushings when the get worn out? If so, seems like the way to go for sure!
Technicaly, the ones I have use bearings (which dont wear out) and they can be replaced...
BTW, you MUST use solid tension rods with the adjusties i have.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
What is your concern--ultimate long life or absolutely rigid (tight feeling) front end? You CAN get unlimited life from the OEM parts with a simple modification--simply install a grease zerk fitting in each end of the llink and re-grease every 25K miles.
Takes less than 30 min total for 2 links to drill, tap, install the 4 zerks, costs less than $5 for the zerks, $5 for lifetime supply of Mobil 1 synthetic moly-sulfide grease
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
texasoil wrote:[...]--simply install a grease zerk fitting in each end of the llink and re-grease every 25K miles.
Where do the zerks go? A pic would be nice ... I know I asked specifically where they go already, and got zilch....as in non-specific statement like above. (simply?)
Have you actually done this or not?
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
I'd be afraid of drilling new ones for fear of damaging the bushings or contaminating with metal shavings. I guess I could try it with a used set and install the poly 300zx bushings?
texasoil
'94 Infiniti Q45A
I have attached photos. RE:shavings--use grease on bit and tap--no shavings problem. Yes I have done it successfully.Not difficult.
texasoil
'94 Infiniti Q45A
inboard zerk photo right side upper link 92Q45a shown--over 50K miles on rough Houston streets and terrible freeways--still has IDENTICAL movement as measured by dial indicator per FSM procedure--within 0.001"
I have to say it does work. Grease used is Mobil1 synthetic moly-sulfide (same as used on ball-joints and brake caliper sliding pins,etc.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45denver wrote:I'd be afraid of drilling new ones for fear of damaging the bushings or contaminating with metal shavings.
My question also is how deep can one drill and not hit the inner journal?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
maxnix wrote:My question also is how deep can one drill and not hit the inner journal?
So maybe I need to take an upper link apart?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Texas Oil (Keith) Any chance you can please upload these photos?
Infinitiguy19
Cut apart my spare (trashed) outer tie rods. They have a plastic liner surrounded by old grease. I take it the outer tie rod ends can't be made grease-able via Zerk fittings?
From what I read online sealed components are made to stay sealed...? Texasoil do you still lurk on NICO?
