Thanks, Starter. I'll now definitely ask them to assess and let me know before they go ahead with any replacements. I'm thinking of going to the closer shop that does all cars - is there a particular brand of non-oem pads/rotors I should mention or look out for?Starter wrote:That kind of brake work is as common as it gets. Any shop should be able to do it.
Be careful about them selling you something you don't need - like replacing rotors if there is enough material left. Also assuming there is no warpage on the rotors and they aren't grooved you may not need to turn them. Check out Tire Rack for decent prices on both pads and rotors.
Depends on the driving you do. Just driving around most any brand will be OK. For a little more spirited driving I like the Akebono pads. (they are OEM too). For even more vigorous driving there are a number of aftermarket rotors available including either grooved or drilled ones. They look cool but you will never drive fast enough, long enough on the street to see any advantage. There are plenty of brands of high performance pads too. I'd stay away from any that aren't all ceramic. The metallic and combo ceramic/metallic tend to eat rotors - not to mention a fair amount of noise and lots of dust.diecast wrote:Thanks, Starter. I'll now definitely ask them to assess and let me know before they go ahead with any replacements. I'm thinking of going to the closer shop that does all cars - is there a particular brand of non-oem pads/rotors I should mention or look out for?Starter wrote:That kind of brake work is as common as it gets. Any shop should be able to do it.
In a month, this car will be used mainly for leisure (it was used for commuting the past year). But when I do drive it, there are moments where I like to have a little fun. Nothing crazy though.Starter wrote: Depends on the driving you do. Just driving around most any brand will be OK. For a little more spirited driving I like the Akebono pads. (they are OEM too). For even more vigorous driving there are a number of aftermarket rotors available including either grooved or drilled ones. They look cool but you will never drive fast enough, long enough on the street to see any advantage. There are plenty of brands of high performance pads too. I'd stay away from any that aren't all ceramic. The metallic and combo ceramic/metallic tend to eat rotors - not to mention a fair amount of noise and lots of dust.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
