Anyone with a Y33 looking to go 5 speed? look in here
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
I was in the process of a vh41/z32 swap in my s14, but ended up parting it out. Figured someone with a y33 might want to hop an an almost complete swap for a VH41.
Heres what I have
NA z32 transmission with milled bellhousing for the adapter plate
xcessive manufacturing shortened shifter bracket
www.swap1uz.com vh41 adapter plate
z32 OEM flywheel with the starter ring flipped for use with the OE 4.1 starter was turned but some surface rust from sitting unused
spec stage 3 sprung clutch
mazworx z32 short shifter
From there you would need the obvious, transmission crossmember, driveshaft and a clutch pedal.
Flywheel has some surface rust from the swap sitting in my s14s engine bay, but nothing terrible. Spec clutch is brand new, only installed for mock up on my setup. Transmission was milled by a local machine shop, reassembled by myself. Everythings ready to be bolted up and finally used!
I have over $1500 invest in the setup, looking to get 1200 obo + shipping.
jblack2013
Car: 1998 q45t Black on Black
Im interested in this setup. I live in florida as well, I could pick it up over the weekend. Please pm me with more details. thanks
IThaJ0kaI
Sent you a PM!
jblack2013
IThaJ0kaI wrote:Sent you a PM!
Ok thanks, ill give you a call Wednesday sometime
IThaJ0kaI
Also have a 350z 6 speed cut setup to be used with this adapter plate, instead of the 5 speed box if anyone is interested. Price would be 1500 obo with the z33 box setup.
IThaJ0kaI
someone buy this.
