I ran 87 for about a year, then ran 93 for about 6 months, noticed no difference, and went back to 87.MinisterofDOOM wrote:Premium will make a bit more power, but regular is perfectly fine in your '03 (and really any Max without a VG under the hood).
In 2 1/2 years and 61k miles on my 2006 G35 Sedan, all I use is regular with no problemsAcMav wrote:Ive used regular in my I30t for years, i just recently switched to premium because my knock sensor went bad so its worth it for me to use premium instead. I've had no problems on regular fuel.
making me jealous...can you ship some up to MT?rxm6 wrote:There is a pump at the gas station by my house with 100 octane. Lord knows I've been tempted....
20cents extra/gallon is worth it. we're paying so much at the pumps anymore that your wallet won't even notice a $3 diference, but your car will.MrMax03 wrote:Is it worth the extra $$ 03 GLE
maxhopper97 wrote:The fuel maps are designed to run most efficiently on premium. Using lower grade fuel will result in the knock sensor retarding timing and therefore decreasing performance. By decreasing performance, you get worse mileage per gallon.
For example: Say your standard fill is 15 gallons. Using regular grade fuel saves you $3 (saving $.20/gallon). Using permium you get 28mpg. Using regular grade you get 26mpg. Computing that out to miles per fill equates to 420 miles per tank with premium .vs 390 miles per tank with regular. That is a 30 mile difference which is over 1 gallon's worth of fuel, which at $4/gallon: you just lost over $4 to save $3.
This is just an example, since I only run premium, I have no idea what kind of mileage my Max would get on regular. This is just to point out that saving money on the front end could wind up costing you more in the long run.
i bet how much is a gallon though? bout $20?kzoosho wrote:I running 116 daily lol. No problems here.
Do you live in teh USSR?rxm6 wrote:There is a pump at the gas station by my house with 100 octane. Lord knows I've been tempted....
E85 only works correctly in cars that are designed to run on it. It's octane rating is higher than normal pump gasoline, but it's closer to 100 than 110. Ethanol CAN produce good power, but motors must be designed specifically for it. Flex fuel (dual-fuel gas and/or E85) engines found in commercial consumer automobiles run less efficiently on E85 than on gasoline.johnnyd6404 wrote:What about E85 I have heard that ethanol is like 110 octane is this true? I know all the indy cars use it so it must produce some decent power. In places like Brasil they use pure ethanol and its half the price of regular gas...only if it worked in the cold
Unless you're running with some boost, don't do it. You'll blow a ton of money for absolutely no gain.rxm6 wrote:There is a pump at the gas station by my house with 100 octane. Lord knows I've been tempted....
