Interesting, Now I can say that I have read Finnish!krayton wrote:http://www.alien2nrs.com/blog/....html
heres some pics. you can see the pin pulled out. i just cannot get mine out
think im getting it. so you took it apart the other way basically? instead of going the front way through the shaft. you went through the back? (the front of the cas)eh? wrote:I was afraid of bending the shaft when I tried to remove the small pin with a hammer and pin punch. What I ended up doing is taking a needle nose vicegrip and cracking loose the two small retainer screws. You may have to press out the shaft after removing the screws ( I can't remember). If you remove the black rubber center piece on the front of the cas you'll be able to see the end of the shaft to press it out. That will enable you to remove that portion of the shaft and you'll be able to get to the wheel. I reinstalled the same way with the vicegrip too, just added a bit of loctite on the screws for insurance. I haven't had any issues since.
sweet...but not really?Coolwhip wrote:I'll try to find the link to a write up I came across that shows how to take them apart.
However, there are 2 kinds and one can not be taken apart, you'll end up damaging the sensor.
krayton wrote: hand job.
