akwikz »
https://forums.nicoclub.com/akwikz-u44134.html
Sun Mar 15, 2009 10:28 am
First off, the C10 Hakosuka ('69-'72) was not the first Skyline. The Skyline started back in 1957.
Now to your request. You are looking at a minimum of $15k for a running Hakosuka. Four doors are a bit cheaper than 2 doors. The four door was made from '69-'72 while the two door was only offered for '71 and '72. Realistically you should expect to pay between $20-$25k for a good 2 door. Like any other classic car, it has specific rust prone problems. The spare tire well, the lower rockers beneath the doors, and at the base of the rear window. At the lower end of the price spectrum expect to need to cut out some rust in one of these spots. If price is not much of an issue, I suggest buying a $30k car. At this range the car will be nearly perfect. You can just drive it and not worry about it needing any repairs. I brought in my '71 2 door five years ago. And back then it ran me around $14k. My car had a little rust, a beat down suspension, and tired stock motor. None of this mattered to me as I had planned to replace it all anyhow. I only mention it because that is what you should expect for $15k.Plan another $1500-$2000 for shipping and customs fees. Of course all of this also depends upon you doing it all yourself. No matter what, it is a time consuming process.
Brian
