Qxxx4 wrote:Id like to light up the floor in white LED i.e lights under the dashboard....but i cant seem to find where to tap into. I found "room light" on inside fuse box, but upon removing that fuse the lights still work, any ideas?
I'll post pics of what I did when I get around to it. I wired a potentiometer in line with 10 12v LED's to an AC wire. Once I figured out the correct resistance I was able to dim them smoothly. I went on a lighting forum for advice and they said it couldn't be done. I drilled evenly spaced holes in the plastic shield under the steering wheel and siliconed them through the holes. I wired all the LED's into the terminal block, then to the pot, then to the AC wire. The only tough part was finding the right pot. Here's a pic of one of the LED's with the resistor shown.
Billy
Modified by Empty V at 11:00 PM 8/9/2009
